transcendental
Member since June 2014
Post by transcendental on Jun 10, 2014 15:22:54 GMT -5
My first attempt at a bracelet (been done for a bit bit just found the rose clasps I knew I had hidden in my bead bin) also second attempt at a ring ( first was with a crystal point) not perfect but I'm happy with how it turned out. The earnings and 2 bits on the bracelet were one piece I shattered to make sure they matched. The ring sits kind of high so not for everyday wear, but I was just trying to have fun with it. Here's the backside of the bracelet, not the prettiest... I think my experience with sewing has me paranoid my ends will come loose and slip out :/ had to stitch (not sure if that term applies hopefully you can understand what I mean) the little roses onto the cage
Post by rockjunquie on Jun 10, 2014 21:04:52 GMT -5
Wow! You really pulled out all the stops on these! I see some of those "bead eyes" (herringbone weave). I remember the first time I saw those done by Eni Oken. It blew my socks off and I had to buy the book. Sadly, I can't wrap a cab with it. Yours look great, as do the roses. Nice set!
transcendental
Post by transcendental on Jun 10, 2014 21:55:19 GMT -5
Thank you I had been watching tutorial videos for about a week and tried to put as much into it as I could to try a bunch all at once. This is the herringbone tutorial I watched, really good. How to Create a Herringbone Wire Wrapped Bead: Hope the link works have trouble with the thicker wire, this I used 26g... teeny tiny stuff. I actually added a drop of jewelers glue to the backsides of each because the wire was so thin I was afraid with excessive wear they might snap off, really helped to add support, bubbled a bit on the earnings but can't really see it unless your examining it closely as it dries clear.
Post by snowmom on Jun 11, 2014 4:45:19 GMT -5
I see hours and hours of hard work here. Pretty stones, too!
transcendental
Post by transcendental on Jun 11, 2014 7:31:44 GMT -5
Thanks Yeah took a while and 2 tries to get the bracelet to hold the stones
