unclestu
WINNER OF THE FIRST RTH KILLER CAB CONTEST UNCLESTU'S AGUA NUEVA AGATE
Member since April 2011
Post by unclestu on Jun 19, 2014 15:50:20 GMT -5
I wanted to try doing a groove wrap, but I first have to become groovy. So in order to get into the groove I need to get a groove making machine. I was thinking about one of thoe Gryphon machines with a groove bit. Would that be the way to go? What other type of machines do you other groovy groove making people use to make your grooves in your cabs? Stu
Thunder69
Thunder 2000-2015
Post by Thunder69 on Jun 19, 2014 19:00:52 GMT -5
Stu that is the best path to getting your groove on...I have a swap top that I use ....I like it ...John
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Jun 20, 2014 13:11:14 GMT -5
the other way to do a groove, a little... make that a fair bit more involved... is to use a foredom with a diamond cutting wheel or a dremel. clamp it down and use it to cut the groove then turn it over and cut the other half of the groove. at the rock club I belong to they use a block of wood with a hole in it and a slot cut into it with a thumb screw that you tighten to position the foredom tool to the position that is needed. it's not difficult, but has a broader learning curve than using the gryphon machine or the swap top. Good Luck with it!!
