thewiz
"What good is money if you don't spend it"
Member since January 2004
Post by thewiz on May 8, 2004 19:56:37 GMT -5
hello all i had my second load in polish. checked it after a week and the shine was not there. so i cleaned it out and used aluminum oxide instead of the cerium and after three days its looking better. don't know whats up with that, but this happened with both batches
llanago
Post by llanago on May 8, 2004 20:09:01 GMT -5
Wiz, I'm not experienced enough to even offer suggestions as to what to do or what polish to use. My first batch did not polish at all and I took some of them to the rock show and asked people why. Most of them said because I probably didn't leave them in the pre-polish long enough. Since then, I have kept them in prepolish at least 8 to 10 days. I don't even know what kind of polish I use! I got it at the rock shop and the lady there said it is just a generic polish. All I know is it puts a nice shine on most of my stones. A few haven't polished well and when I get enough of them to fill a barrel, I will put them through prepolish again and try one of the other kinds of polish I have (aluminum oxide and cerium oxide). If that doesn't work, I'll have to try something else or I'll just not worry about them because they aren't my favorite stones anyway!
James
Member since October 2003
Post by James on May 9, 2004 2:50:49 GMT -5
What kind of stone?
Post by puppie96 on May 9, 2004 3:49:35 GMT -5
Curiously enough, my early batches polished beautifully. I had no failures until recently. Still don't know why. Repolishing with the proprietary polish that comes with Raytech vibe kits solved one batch. For the other I went back several steps and it worked fine when I next tried to polish.
llanago
Post by llanago on May 9, 2004 9:10:18 GMT -5
What kind of stone? Oh James, you are too funny! ;D What kind of stone? LOL! But then, I guess everybody else actually knows what kind of stone they are tumbling.
MichiganRocks
"I wasn't born to follow."
Member since April 2007
Post by MichiganRocks on May 9, 2004 9:44:07 GMT -5
Don't forget, it's not always "what" you used. The smallest bit of contamination can cause some terrible results (been there, done that). Small cracks, crevices, or pits can be very difficult to clean of old grit. I have become very picky about letting any type of imperfection into the pre-polish or polish stage. Just a thought. Ron
Post by puppie96 on May 10, 2004 1:11:17 GMT -5
Now here's something funny. I've always read about removing rocks with crevices or holes and have followed the directions. This time I let a a fair number through with small pits or cracks and a few with fairly big ones. It just seemed as if the whole batch had these imperfections and further grinding would never remove them. Also, some of it was local rock -- I don't know what anything is -- it's stuff that's a bit geode like, you sometimes find twisty layers of crystals or hollows with crystals inside -- and the interior effect makes it interesting. To my somewhat surprise, the whole batch polished up beautifully, including the ones with the holes and stuff.
Post by creativeminded on May 10, 2004 14:31:46 GMT -5
I had the same problem with my sweetwater agate just about every piece had a deep hole or crevas in it and they turned out very good. The Turtle wax really didn't chnge the shine much, but I am satisfied with the results. Tami
Post by cookie3rocks on May 10, 2004 21:32:57 GMT -5
I so missed thinger and sthingys. I think that would be sweet w a t e r. I have a RaytechVibe 5 and the polish that came with the kit. Only thing is, there are no instrutions on how much to use per pound. all the other grits are very specific. Any ideas? (so glad to be back!)
cookie
Post by creativeminded on May 11, 2004 10:48:30 GMT -5
Yes it is sweet water agate...LOL...LOL.... Tami
James
Post by James on May 11, 2004 14:47:23 GMT -5
If you look closely there is a "bad" word in the middle of swee-t-w-a-t-er. That's why it censored it. Just like s-poon. See that one? I find it kinda comical.
Post by rockyraccoon on May 11, 2004 22:40:23 GMT -5
i don't see the bad word in spoon s-poon. is there a bad word i don't know . somebody fill me in! i need to know all the bad words ;D. kim
Post by cookie3rocks on May 11, 2004 23:01:52 GMT -5
I'm just guessing here, but , considering Andy is british, and he administrates this web site, and he was the one to say "OK, I'll change that", "Poon' must be a bad word in the UK. Andy, let me know ;D
.cookie
James
Post by James on May 12, 2004 2:35:09 GMT -5
Didn't you guys ever see the movie Platoon? Remember "poontang?" Pardon my my French.
Post by rockyraccoon on May 12, 2004 9:31:57 GMT -5
well now that you mention it i believe i have heard of that but without your input that revelation was not forthcoming on its own. 10 yrs from now i'd still be trying to figure it out like one of those word puzzles. thanks james!
kim
llanago
Post by llanago on May 12, 2004 10:34:33 GMT -5
Cookie, is your Raytech a 6#r? That's what I have. The instructions that I got call for 2 teaspoons of polish and 4 tablespoons of water if the rocks are dry. If the rocks are wet, 2 tablespoons of water. They say you are suppose to clean them and recharge in 24 hrs. but I never do. After 24 hours, I take out a couple of rocks and see how they look. I then usually just add another couple of teaspoons of polish and a bit of water if needed.
I really like the Raytech because it uses so little polish and puts a high shine on my rocks in about two days. I am not using the polish that came with it right now because I have had such good results with the polish I already had. Guess I should try the polish that came with it, just to see what kind of job it does.
Post by cookie3rocks on May 12, 2004 11:45:13 GMT -5
Mine is a 3#. You mean literaly that small amount of water? I've been filling 3/4 full. No wonder my polish stage never does weel Thanks cookie
