FLrockhound
Member since July 2014
Post by FLrockhound on Jul 21, 2014 15:27:46 GMT -5
Here's the tumbler I just put together using scrap wood i had laying around and a 3speed box fan motor. It works okay now but I already see what I need to improve, such as a simple pulley reduction and some brass fittings for the rollers which are just spinning freely in the wood.. friction is becoming an issue even with oil. I have a Lortone 45C but that's just not enough for me. 34"x8" using 1/2" aluminum tubing wrapped in heat shrink direct to the motor. The barrels are 12"x4" PVC. Thanks for checking it out.
garock
Member since February 2006
Post by garock on Jul 21, 2014 17:40:27 GMT -5
Your Avatar picture look exactly like a cat I had named "Blue Eyes" ! Miss him ! your tumbler is a great start ! I started with a tumbler many "moons ago"('bout 54 years) very similar to yours. Keep "ciphering" as Jethro Bodine would say and things work out pretty good for you. I done a lot of T & E Engineering, Trial and Error but it made me smarter ! I hope !
FLrockhound
Post by FLrockhound on Jul 21, 2014 17:48:56 GMT -5
That's my wife's cat nicknamed "Dumb Eyes", real name is "Rajsha". It wouldn't be any fun if all projects were done right the first time. I look at is a learning expeerience also. The revisioned tumbler will be alot nicer. i might go all out and make a table and make it look fancy. little side projects like that one are what will keep me busy while waiting for a batch to finish.
Post by jamesp on Jul 21, 2014 20:04:04 GMT -5
3 speed fan motor is a great idea. Wood frame is perfect. PVC is great for barrels. well done.
FLrockhound
Post by FLrockhound on Jul 22, 2014 13:25:46 GMT -5
3 speed fan motor is a great idea. Wood frame is perfect. PVC is great for barrels. well done. Thanks, looks a little janky right now but, now that I have something to work with it'll be easier to make improvements.
Post by jamesp on Jul 22, 2014 14:45:52 GMT -5
3 speed fan motor is a great idea. Wood frame is perfect. PVC is great for barrels. well done. Thanks, looks a little janky right now but, now that I have something to work with it'll be easier to make improvements. If it helps, this was the first one I built and it is sweet. 1000RPM 1/8 HP fan motor. Purrs like a kitten. It sits on a slight slant so the barrel will go to the one guide roller on the right. It will run 35 pound barrels.
FLrockhound
Post by FLrockhound on Jul 23, 2014 18:53:43 GMT -5
Thanks, looks a little janky right now but, now that I have something to work with it'll be easier to make improvements. If it helps, this was the first one I built and it is sweet. 1000RPM 1/8 HP fan motor. Purrs like a kitten. It sits on a slight slant so the barrel will go to the one guide roller on the right. It will run 35 pound barrels. That's pretty nice, 35lbs is something I would like to shoot for but multiple smaller barrels to keep me busy. Right now I can only tumble about 10lbs at a time until I get a bigger motor and stronger rollers.
FLrockhound
Post by FLrockhound on Jul 24, 2014 11:04:02 GMT -5
That's my wife's cat nicknamed "Dumb Eyes", real name is "Rajsha". It wouldn't be any fun if all projects were done right the first time. I look at is a learning expeerience also. The revisioned tumbler will be alot nicer. I might go all out and make a table and make it look fancy. little side projects like that one are what will keep me busy while waiting for a batch to finish.
