Post by stardiamond on Jul 31, 2014 22:57:58 GMT -5
Eloxite had a sale on mk303 8" .032 saw blades in January 2013. I ordered 2 by phone and specified a 1" arbor (what my Genie trim saw requires). I quit doing lapidary until now to grow roses. I unpacked the box today and they have a 5/8" arbor. There is no point contacting Eloxite because they don't sell the blade with a one inch arbor. Is this something I can get fixed reasonably at a machine shop? An ebay seller used to redrill the holes to one inch. Is this something I could attempt myself?
Post by catmandewe on Jul 31, 2014 23:41:50 GMT -5
You can do it yourself with a drill press, first put a 5/8 bit in the drill and center the blade around it, then clamp the blade down so it can't move. Then switch to a 1" bit and drill your hole.
Easey Peasey Lemon Squeezee!
Tony
Post by parfive on Aug 1, 2014 0:53:42 GMT -5
Unibit.
Two birds w/one stone.
Post by Rockoonz on Aug 2, 2014 2:40:36 GMT -5
Post by stardiamond on Aug 2, 2014 12:33:25 GMT -5
Thanks. I ordered one. If it works ok, I can order more of the blades with the smaller hole. The one inch generally cost more.
Post by Rockoonz on Aug 2, 2014 12:47:48 GMT -5
stardiamond when you use the step drill take a permanent marker and mark the next step larger than the diameter you intend to go to so you don't accidently make the hole too big. Don't ask how I learned this.
