Post by Deleted on Aug 11, 2014 20:48:36 GMT -5
Anybody out there in RTH land have a line on a new arbor bearing for 10" raytec pro.supposesly"sealed and lubed for life".not.maybe if I was slabbing limestone.lol Thanks a bunch for any help Dave
Post by johnjsgems on Aug 12, 2014 13:45:06 GMT -5
Lubed for life of bearing, not your life. If the bearing is removable look for numbers and manufacturer on inner race or seal cover (like "Fafnir RAK12", etc.). Other than that measure bore, OD, and width and check outer shape (flat or rounded), set screw or locking collar, etc. and search online or any bearing supplier. Or contact the guy that just bought out the Raytech lapidary line. If it is a "water pump" type bearing with bearings in one long housing you may be forced to buy from the manufacturer. Most companies don't make their own bearings or use OEM bearings so if you get complete specs you should be able to find a replacement.
Post by Deleted on Aug 12, 2014 16:31:44 GMT -5
Thank you sir.sent you a pm
