vugs
Rockbiter
Member since February 2014
Post by vugs on Aug 12, 2014 17:13:07 GMT -5
Hi All, i just got a nice 10" Frantom saw. Pretty happy about it too.. It's just the saw, vise/fence, splashguard, pulley. No base or motor. I have a motor for it already and will be getting it all up and running asap but i wanted to ask the diy'ers to show me some simple diy adjustable motor mount ideas. Any feedback is appreciated.
Post by DirtCleaner on Aug 12, 2014 22:18:16 GMT -5
I have a few things to put together too and would also like to see some DIY pics.
Post by Drummond Island Rocks on Aug 13, 2014 6:48:56 GMT -5
Post by Peruano on Aug 13, 2014 7:58:23 GMT -5
Chuck is obviously a better craftsman than I am, but here's the same idea on my slab saw. I had to add a bit of weight to the motor to increase belt tension to match that needed for the saw. Cheers. Tom
vugs
Rockbiter
Post by vugs on Aug 13, 2014 8:52:20 GMT -5
Peruano and Drummond Island Rocks thanks guys, i appreciate it. And, Chuck, thanks for that link. I had seen one of those on Ebay before and was trying to find one on there again.
electricmonk
Member since August 2011
Post by electricmonk on Aug 13, 2014 9:39:14 GMT -5
My personal "variation on theme", the grommets help with vibration, have a pair of "jam nuts" below to allow for a positive stop and the ability to custom tension the belt independent of weight and reduces motor "jumping" particularly on startup. Can't say I have a history of doing such things, might be some unknown drawbacks that I am just not experienced enough to be aware of. Cheers
Post by johnjsgems on Aug 13, 2014 12:59:08 GMT -5
Most of the trim saws I set up I just mount the motor on the base board behind the saw. I put the belt on and pull motor back straight. Mark and drill the motor mounts in center of slots. Mounting under the saw the hinged plate and threaded rod works well. I would use a metal plate to bolt to motor mount and hinge it from the saw stand. Threaded rod to adjust tension. Motor weight works but something about the motor jumping and bouncing at start up turns me off. Less likely to slip when hand feeding a little too aggressively too.
vugs
Rockbiter
Post by vugs on Aug 13, 2014 14:08:39 GMT -5
Thanks guys i will take this advice and probably build something similar although i like the one in the link Chuck posted but i don't want to pay that much. i may have to shoot the seller an offer and see if he's willing to deal. Thanks for posting these pics for referencing guys. i appreciate it.
Steve
Member since June 2005
Post by Steve on Aug 13, 2014 16:17:18 GMT -5
Post by johnjsgems on Aug 13, 2014 20:12:34 GMT -5
If you buy a sliding base be sure to match your motor frame. Motor tag will say something like "FR 48Y" or "FR 56". I think you are over engineering it myself. Use a good quality belt and it should not stretch much at all over time. I use carriage bolts from the bottom of base board for both saw and motor. That avoids bolt heads sticking out. Also makes it easy to remove saw tank for cleaning. My first saw was a 10" Frantom. I mounted it directly to a 2X work bench top without a base board. Worked fine but made it too hard to move saw to other locations.
vugs
Rockbiter
Post by vugs on Aug 13, 2014 21:16:57 GMT -5
You're probably right about the over engineering but putting this saw together is part "i need a new saw" and part "i want to work on a project". It's the "i want to work on a project" side that over engineers.
Post by quartz on Aug 13, 2014 22:54:49 GMT -5
Our compliments on the rockbiter avatar vugs, fun movie. Like to have that guy along at times.
vugs
Rockbiter
Post by vugs on Aug 14, 2014 2:21:47 GMT -5
Our compliments on the rockbiter avatar vugs, fun movie. Like to have that guy along at times. Thanks. He'd sniff out some good veins but end up eating all the best material haha.. But yea, fun movie.
Post by captbob on Aug 14, 2014 14:50:08 GMT -5
Hey Chuck (Drummond Island Rocks) have you made a thread on your tumbler build? If so, could you please post a link to it here. Looks like a really nice job!
Thank you.
