Post by rockpickerforever on Aug 18, 2014 20:18:47 GMT -5
Picked up this septarian slab at the swapmeet a couple weeks ago. Size is approximately 5 3/4 X 5 X 9/16 inch thick. Front
Back
Backlit
Edge
I would like to use it for a drink coaster, but now wonder if the condensation from a cold glass will affect the calcite center. Do you think it would dissolve over time? (Edit - this cost me $4.)
Also picked up same day, a fist-sized mahogany obsidian chunk o' rock. Paid a whole $1 for this. I asked the guy that had it for sale how much he wanted for his "rock." I never give sellers any information, as then they think what they have is worth more, lol. Do not know where it is from.
DH seems to think that this is a hammer rock, because it fits his hand well, and it looks like it may have been used as such. Me, I don't know why anyone would use something that fractures as easily as obsidian as a hammer rock. Thoughts?
Thanks for looking.
Post by jamesp on Aug 18, 2014 20:27:08 GMT -5
Septarian is a landing pad for small alien space craft.
Post by rockpickerforever on Aug 18, 2014 20:33:51 GMT -5
Especially when lit from below, right James?
Post by jamesp on Aug 18, 2014 21:15:47 GMT -5
Could it be lit from within ? And start pulsing...
Post by Sabre52 on Aug 18, 2014 21:18:53 GMT -5
Great finds! I'd think the septarian would hold up OK as long as you didn't spill acidic drinks on it. I guess you could use krylon or some other sealer to waterproof the slab if you so desired. Obsidian would make a crappy hammerstone. As you've said, just to brittle. Amerinds round here used a lot of quartzite type rocks for that as it is pretty tough. Your example sure has the look of Davis Creek to me as lots of the obsidian from there is in that roughened nodule form and mahogany is common in he area.....Mel
Post by rockpickerforever on Aug 18, 2014 21:31:59 GMT -5
Could it be lit from within ? And start pulsing... What, like drill a hole in it and put a light into the slab? No, it would be better to put it on a raised holder, and just light it from below. The backlit photo posted just had the morning sunshine lighting it. A light in an enclosed box would really make it glow!
Thanks, Mel, exactly what I was thinking, giving the septarian slab a protective coating. And thanks for your insight on it not being a hammerstone. I didn't think so. I guess DH was just going by the fact it fit his hand. I could just see it shattering into a zillion pieces, shards of glass flying every which way, if it was used top strike something hard.
Post by Deleted on Aug 18, 2014 22:40:27 GMT -5
Wife beater rock is probably what he was thinking. Okay, maybe not. I think you have the front and back mixed up on the septigenarian. Jim
Post by rockpickerforever on Aug 19, 2014 5:25:32 GMT -5
Jim, I'm calling the side with the void/hole in it the back (inverted teardrop shape towards top in pic labelled as back). Photo quality is inconsistent, both sides are equally nice. By putting that side down, it won't fill up with dust and dog hair, lol.
Post by nowyo on Aug 19, 2014 23:31:44 GMT -5
Nice finds! I think we need to come down and visit your swap meet. I think Mel's got it, some clear coat to protect the rock and you've got a real neat coaster.
Russ
Post by Pat on Aug 19, 2014 23:40:52 GMT -5
Jean, most of our coasters are slabs. I soften very rough edges, apply a sealer on top, and felt feet on the bottom for air.
If I have ice in my glass, I add a napkin under the glass. One of our coasters is a septarian nodule slab.
Slabs make excellent coasters!
Post by Drummond Island Rocks on Aug 20, 2014 5:40:02 GMT -5
I never had much luck with any spray on or brush on coatings. I have went been using pour on finishes like bar top coating. I just did 3 this weeks but have not taken pictures yet. Here's some I did in the fall. forum.rocktumblinghobby.com/thread/61681/coasters-poured-on-epoxy-finishI use these at my house and the only issue I have found is that sometimes the sweat from a drink will cause a suction and when you lift your glass the slab will lift with it. Chuck
Post by jamesp on Aug 20, 2014 6:58:56 GMT -5
Thicker(heavier)is better for coasters. Slabs do stick to the glass.
Post by rockpickerforever on Aug 20, 2014 11:56:55 GMT -5
Thanks, Russ and Pat! I've not coasted any rocks yet, in fact, I always thought it was cheating when someone would spray a slab to make it shiny, instead of polishing it. I still have slabs picked up at shows that need to be worked and have this removed. Russ, I've picked up some pretty cool stuff at the swap meet, but it is very hit and miss. I actually live just a few blocks, walking distance, from the Spring Valley Swap Meet, but we don't go there very often. The type of people that go there are very rude and pushy. (I'll not stereotype here.) We usually drive out to Santee Swap Meet, about twelve miles away. Some weeks I don't see more than one or two rocks, other times I score! Chuck, I also wondered about the suction between a wet glass and smooth surface, either polished or coated. Not a good thing to have the coaster lift up with the glass, then drop to the floor and possibly break. Or drop back onto glass-topped coffee table. I've got some standard size round coasters made with sandstone. Very porous, so absorbs the water. Glass doesn't stick to coaster, and condensation doesn't pool on top. James, I like the thicker 3/8" thick septarian slab for a coaster as well. The other coasters I have are more like 1/4 inch thick. Only problem is, heavier makes a better projectile . But now, I'll have to be on the lookout for more of them, around the same size. This one was a one-off.
Post by jamesp on Aug 20, 2014 20:20:06 GMT -5
Since I dig in the mud a lot I drill holes in my shovels for suction relief. Makes a big difference. But then your coaster would leak. How about some blood grooves like they put on knives. I suppose impractical. Heavy is easiest.
Post by Pat on Aug 20, 2014 20:34:26 GMT -5
Yes , thicker is better. A friend put down his glass on a regular slab. Broke in two. Two coasters!
I'm in the process of making coasters out of thicker serpentine slabs. Double length --- space for the coffee and the cookie.
Post by jamesp on Aug 20, 2014 21:15:07 GMT -5
Yes , thicker is better. A friend put down his glass on a regular slab. Broke in two. Two coasters! I'm in the process of making coasters out of thicker serpentine slabs. Double length --- space for the coffee and the cookie. What about the cat Pat ?
Post by Deleted on Aug 20, 2014 21:30:49 GMT -5
Yes , thicker is better. A friend put down his glass on a regular slab. Broke in two. Two coasters! I'm in the process of making coasters out of thicker serpentine slabs. Double length --- space for the coffee and the cookie. Oh come on Pat. You give people "ONE" cookie. Who eats one cookie? I would have to drill a hole, insert 10 inch dowel and buy cookies with holes in the middle so I can stack them up. Or a stone bowl with a flat spot on the edge for the drink. I am waiting for someone to say "put a sheet of cork on the top". lol I actually have some slabs of wampidy sunrise that are big enough to put a cup size circle of cork on them and they would hardly be noticed. Jim
Post by Pat on Aug 21, 2014 0:12:21 GMT -5
jamesp The cat doesn't like cookies. It is only the glass of water she sticks her feet in if she cannot reach the water. Apparently, doesn't like coffee either! Nor wine. I like blood lines suggestion. Will have to try it. Any trick to the pattern of bloodlines? @wampidy guests can have how many cookies they want, though I think they enjoy the entire one cookie more than they like scarfing handfuls of cookies! Anyhow, that is how it works for me --- and I prefer them fresh out of the oven, though I have discovered frozen cookies are also wonderful. However, none of our cookies make it to the freezer.
Post by jamesp on Aug 21, 2014 6:21:18 GMT -5
Blood grooves in a bayonet Pat. Makes it easier to pull it out of the body.
Post by Deleted on Aug 21, 2014 15:04:08 GMT -5
jamesp The cat doesn't like cookies. It is only the glass of water she sticks her feet in if she cannot reach the water. Apparently, doesn't like coffee either! Nor wine. I like blood lines suggestion. Will have to try it. Any trick to the pattern of bloodlines? @wampidy guests can have how many cookies they want, though I think they enjoy the entire one cookie more than they like scarfing handfuls of cookies! Anyhow, that is how it works for me --- and I prefer them fresh out of the oven, though I have discovered frozen cookies are also wonderful. However, none of our cookies make it to the freezer. I hope you know that I am kidding right? How about, if I ever go to your house I will take cookies, bunches of cookies? I have this carry bag that would hold many bunches of cookies and they would be much easier to carry than the rocks that are usually in it. And I will put a big old hunk of Wyoming jade in the bottom. lol Have you figured out what you need for the ring yet? Just curious and I am writing to you anyway (or at you)(or about you). Jim Love ya darlin. Just covering all bases here.
