swiper
Member since June 2014
Post by swiper on Aug 27, 2014 23:18:37 GMT -5
Post by glennz01 on Aug 28, 2014 0:09:57 GMT -5
you can probably use it for a saw... my saws both run at or under 1 hp
vugs
Rockbiter
Member since February 2014
Post by vugs on Aug 28, 2014 0:23:36 GMT -5
If you google "treadmill motor lathe" it will bring up a bunch of info on what you need to do to run those motors.
Post by jamesp on Aug 28, 2014 5:27:49 GMT -5
Not a good choice. It is very powerful and uses a lot of power. It is also DC. Better to get a simple AC motor.
garock
Member since February 2006
Post by garock on Aug 28, 2014 10:46:34 GMT -5
I am sure that you would have to use the motor speed controller that came with the tread mill. A lot of treadmills use 220 volts ac as input. The controller will convert the AC to DC. Like Mr James said it uses alot power.
