Post by stardiamond on Sept 4, 2014 18:10:13 GMT -5
I realized that even when I set up my slab saw I will still need to slab small rough and thin or split thick slabs. I do this freehand and the slabs I cut are uneven and splitting a slab is risky. I bought a new saw table for my Genie trim saw and went to the hardware store and got a piece of about 2x2 aluminum L bracket. I used the saw blade to trim the piece to the correct length. I marked and drilled two holes. I taped the bracket to the table and drilled through the bracket into the plastic. I removed to bracket and enlarged the holes in the plastic into slots so they could be moved closer or further from the blade allowing cuts from 1/8" to 1/4". I attached the fence to the table using wing nuts. My trim saw blade is .032 x 8" and has lasted longer since I started cutting slower. The rough is pushed from the bottom to the top of the picture and the blade is located about half way up the fence.
fence
Sept 5, 2014 5:56:55 GMT -5
Post by snowmom on Sept 5, 2014 5:56:55 GMT -5
very clever and useful. thanks for the post!
fence
Sept 5, 2014 9:38:05 GMT -5
Post by Fossilman on Sept 5, 2014 9:38:05 GMT -5
Great idea.......So far my "14" lets me cut any thickness I want,with a bit of engineering..Some guys look at that and say,"Are you sure you can do that"? LOL I guess we will find out..
Did your idea help you out pretty good??
Post by stardiamond on Sept 5, 2014 10:53:44 GMT -5
I'll find out today. I might have to trim the forward corner of the fence to clear the ring that stiffens the blade. I measured it but haven't fitted it yet. I've got some nice stuff to try it out on. I will need to make few test cuts to calibrate the thickness.
The Dad_Ohs
Take me to your Labradorite!!
Member since September 2012
Post by The Dad_Ohs on Sept 5, 2014 18:48:15 GMT -5
I've done much the same with a piece of 2x4 that I cut so it when installed in my trim saw it sits 1/4" away from my blade and then I just move material through it... works great!! but I like your fence better!!
Post by stardiamond on Sept 5, 2014 19:02:01 GMT -5
I picked aluminum because my saw floods the table. There is a guard so I don't get sprayed. It took me too long to get the alignment correct. The Genie trim saw isn't that well anchored and the blade doesn't line up exactly with the table. I also realized that once I got a straight cut started to let the blade go rather than pushing the material against the fence which was actually skewing the blade. Cuts are not perfect, but better than I could do freehand and I didn't want to waste the material or try cutting it on a 16" saw.
