bhiatt
Member since July 2012
Post by bhiatt on Sept 14, 2014 20:56:42 GMT -5
Post by snowmom on Sept 15, 2014 5:19:50 GMT -5
WOW, what a monster! amazing thing. Is the last photo of the place it called home before you captured it? Looks like it might have been fun hauling its big fat body out of there! (did you use a cart or a mule?) I had no idea they got that large!
bhiatt
Post by bhiatt on Sept 15, 2014 12:11:42 GMT -5
that's where it came from. There is a paved road just below. I didn't collect it. Jason Hinkle did in 2008.
bhiatt
Post by bhiatt on Sept 15, 2014 12:13:18 GMT -5
here is better photo.
Post by rockpickerforever on Sept 15, 2014 12:36:15 GMT -5
That is just awesome! I can see that it's big, but how many pounds does it weigh? (Good thing it was uphill from a road, wouldn't want to hike that mother out!)
I saw it was found six years ago. By removing it from that hillside, he made the road/highway safer for travelers. Around here, if you were caught by CHP on that hillside, they'd write you up for being alongside the highway, lol.
In what state was it found?
bhiatt
Post by bhiatt on Sept 15, 2014 14:04:12 GMT -5
27 pounds. Somewhere in Oregon. Ill have to check into location. Jason said it is known location for big t eggs. Ive never heard of it and when I look up info I cant find anything.
bhiatt
Post by bhiatt on Sept 15, 2014 14:08:45 GMT -5
Ashwood, Oregon.
Geoff
Please add 1074 to my post number.
Member since December 2012
Post by Geoff on Sept 15, 2014 16:12:32 GMT -5
That's a huge egg!
Post by gingerkid on Sept 15, 2014 20:05:13 GMT -5
Woah, that's a monsta t-egg, and thanks for sharing it with us, bhiatt.
Post by Deleted on Sept 16, 2014 22:30:18 GMT -5
Put some red lipstick on and give it a big kiss!
Am I the only one thinks it looks like a huge set of kissable lips??
Post by Deleted on Sept 16, 2014 22:36:32 GMT -5
"downtown" Ashwood is like 5 miles from Richardson's Ranch!
Seems like maybe a drive thru every road cut might be worthwhile in that neighborhood! I am gonna guess Tub Spring's Road. Just sayin'...
Post by Fossilman on Sept 16, 2014 23:29:15 GMT -5
Great egg country in that area! Seen eggs from there coming in at over a 1000 pounds too..........Their in a museum in Hillsboro,OR..
Post by Pat on Sept 16, 2014 23:55:33 GMT -5
Yep! Big lips as Scott says.
Post by Fossilman on Sept 17, 2014 8:32:12 GMT -5
Mick Jagger
spiritstone
Member since August 2014
Post by spiritstone on Sept 17, 2014 11:14:06 GMT -5
What sort of machine do you use to polish something that size?
Post by jamesp on Sept 17, 2014 16:04:00 GMT -5
What sort of machine do you use to polish something that size? spiritstone:
Post by jamesp on Sept 17, 2014 16:04:58 GMT -5
Brad-Thunder Dome
Post by jamesp on Sept 17, 2014 16:06:11 GMT -5
I almost fell out. Ribs sore. Yu funny.
spiritstone
Post by spiritstone on Sept 17, 2014 17:49:18 GMT -5
What sort of machine do you use to polish something that size? spiritstone: So whats the difference between that one and a angle grinder with a rubber backing plate, because it supply's a water flow. Thanks James.
Post by jamesp on Sept 17, 2014 17:55:19 GMT -5
spiritstone: So whats the difference between that one and a angle grinder with a rubber backing plate, because it supply's a water flow. Thanks James. It also turns at 3600 RPM instead of 12,000 RPM to avoid melting rubber impregnated pads spirit. metal angle grinders turn at 12,000. So motor speed is special too. Those grinders will give you a good soaking, best to have your young bikini clad neighbor lady run it whilst you watch
