Post by stardiamond on Sept 16, 2014 18:11:24 GMT -5
I got this item on ebay for $6.75 delivered. .6 pounds from a seller in North Carolina who doesn't sell rocks. Says it was found in Washington. I liked the colors.
Post by jakesrocks on Sept 16, 2014 18:43:21 GMT -5
It'll be interesting to see the colors after you take a slice or 2 off of it. It may be completely different after you cut away the surface tarnish. Be sure to post an after cutting pic.
panamark
Member since September 2012
Post by panamark on Sept 16, 2014 18:44:52 GMT -5
Has potential. Please post a slab picture
Post by Fossilman on Sept 16, 2014 18:56:38 GMT -5
What kind of rock is it??
Post by stardiamond on Sept 16, 2014 19:01:25 GMT -5
It'll be interesting to see the colors after you take a slice or 2 off of it. It may be completely different after you cut away the surface tarnish. Be sure to post an after cutting pic. Yes, I've learned with some rocks, beauty is only skin deep. Montana for example and I believe Lakers.
Post by stardiamond on Sept 16, 2014 19:16:56 GMT -5
It was listed as a jasper so I assumed the color would remain on the inside. I call these things pony rocks because I'm looking for the pony under the pile of ****
Post by stardiamond on Sept 19, 2014 14:42:10 GMT -5
Rock arrived today. Not what I expected, but I should get some cabs from it. Pattern goes all the way through.
Post by Fossilman on Sept 19, 2014 16:56:50 GMT -5
A bit different than the other photo....
