Post by broseph82 on Sept 26, 2014 14:42:42 GMT -5
Can I put a 7 inch diamond wet saw blade on my trim saw setup? I think the motor runs 1725rpm and the blade has a max of 5000rpm, but will it run good at the lower speed?
Post by deb193redux on Sept 26, 2014 16:23:08 GMT -5
What is you trim saw setup? What size? Room for blade? Any pulleys changing RPM?
Post by broseph82 on Sept 26, 2014 18:25:24 GMT -5
What is you trim saw setup? What size? Room for blade? Any pulleys changing RPM? I have a Rock Rascal model J setup which consists of a water well, top half, blade guard, small pulley near blade and large in back. The hole on top only measures 6.5" so it looks like I'll need a 6" blade not a 7".
Post by Rockoonz on Sept 27, 2014 0:10:16 GMT -5
You are correct, the Rock Rascal will only take a 6 inch blade max. With a 1725 RPM motor I use a 3 inch pulley on the motor with a 2 inch pulley at the blade for about 2500RPM at the blade on my 6 inch trim saw.
Post by broseph82 on Sept 28, 2014 21:01:30 GMT -5
You are correct, the Rock Rascal will only take a 6 inch blade max. With a 1725 RPM motor I use a 3 inch pulley on the motor with a 2 inch pulley at the blade for about 2500RPM at the blade on my 6 inch trim saw. Thanks
Post by deb193redux on Sept 28, 2014 22:46:25 GMT -5
I had a RR for a while. I had best results with a 303c, but I also did OK with a Gorilla Blade. My hand is heavy, so the thicker 303 worked best for me.
I agree you can push the speed a bit. The newer steel blades perform better then when a lot for the speed charts were made.
Post by johnjsgems on Sept 29, 2014 10:49:50 GMT -5
You will need 1/2" arbor size too.
