Post by broseph82 on Sept 28, 2014 20:57:25 GMT -5
spiritstone
Member since August 2014
Post by spiritstone on Sept 28, 2014 21:17:56 GMT -5
Have you done any hardness checks to see if its a jasper. I still wonder if you have a mix of agate and common opal on a few of your finds. Keep us posted if you get the chance.
Post by broseph82 on Sept 28, 2014 21:40:35 GMT -5
Have you done any hardness checks to see if its a jasper. I still wonder if you have a mix of agate and common opal on a few of your finds. Keep us posted if you if you get the chance. How would I go about that?
Post by Fossilman on Sept 28, 2014 22:14:46 GMT -5
That last photo looks like agate and common opal...
spiritstone
Post by spiritstone on Sept 28, 2014 22:24:36 GMT -5
Have you done any hardness checks to see if its a jasper. I still wonder if you have a mix of agate and common opal on a few of your finds. Keep us posted if you if you get the chance. How would I go about that? Nov 22, 2013 at 2:39pm QuotePost Options Post by 1dave on Nov 22, 2013 at 2:39pm Hardness: A Simplified Hardness Scale: 1 and 2 may be scratched with your fingernail 3 may barely be scratched with a penny 4 is easily scratched with a knife 5 may barely be scratched with a knife. 6 will scratch a knife. 7 will scratch glass 8 will scratch quartz. In 1812 the Mohs scale of mineral hardness was devised by the German mineralogist Frederich Mohs (1773-1839), who selected these ten minerals because they were common or readily available. The scale is somewhat arbitrary. 01.Talc . . . . . . . . . 02. Gypsum 03. Calcite . . . . . . . 04. Fluorite 05. Apatite . . . . . . . 06. Feldspar 07. Quartz . . . . . . . 08. Topaz 09. Corundum . . . . . 10. Diamond But in "reality," Fluorite is more than ten times as hard as gypsum so more accuracy can be determined by measuring with a sclerometer, so "make it as hard as you want to." Sclerometer Here, The Mohs Scale is on the left. On the right is the Absolute Hardness where Diamond is 1600. 1 - TALC - . . . . . . 1 2 - GYPSUM - . . . . 2 3 - CALCITE - . . . . 9 4 - FLUORITE - . . . 21 5 - APATITE - . . . . 48 6 - FELDSPAR - . . . 72 7 - QUARTZ - . . . . 100 8 - TOPAZ - . . . . . 200 9 - CORUNDUM - . . 400 10 - DIAMOND - . . 1600 More minerals can be found at: www.classicgems.net/Hardness.htmI particularly like: www.jewelry-secrets.com/Other/Wh ... Scale.html
Post by roy on Sept 28, 2014 23:04:09 GMT -5
nice finds !!!!!
transcendental
Member since June 2014
Post by transcendental on Sept 29, 2014 7:00:56 GMT -5
If your using a penny to check hardness, make sure its an old penny. I use the ones that have "one cent" written out on the back side. Pennies contain less and less copper the newer they are.
Post by snowmom on Sept 29, 2014 14:13:07 GMT -5
good looking stuff! that first one fairly glows... such a deep red!
Post by broseph82 on Sept 29, 2014 19:22:50 GMT -5
good looking stuff! that first one fairly glows... such a deep red! I Slabbed some of these today! Will post in a bit
Post by jamesp on Sept 30, 2014 5:12:38 GMT -5
Post by broseph82 on Sept 30, 2014 15:28:44 GMT -5
Wow jamesp, those are nice. Here is the 3rd pic (with the red agate on the tip) slabbed
Henry
Post by Henry on Oct 2, 2014 12:06:02 GMT -5
Nice colors...especially the red one!
