Geoff
Please add 1074 to my post number.
Member since December 2012
Post by Geoff on Sept 30, 2014 1:15:24 GMT -5
Post by snowmom on Sept 30, 2014 5:30:36 GMT -5
wow, that'll at least help pay for the tire. keep posting, love seeing your adventures (and your finds!)
Post by Jugglerguy on Sept 30, 2014 5:45:32 GMT -5
Nice nuggets! I like how you did your video, the different camera angles looked great.
How did you get your trailer home?
Post by jamesp on Sept 30, 2014 6:35:10 GMT -5
What do you think about the little Keene dredge Geoff ?? www.keeneeng.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=2004PJF&Category_Code=I got one a long time ago and removed the sluice and replaced it with a basket for sucking Florida sand and spitting out arrowheads and fossils. That little Honda motor is a fine machine. Use it all over the place in my water plant biz. Man that thing can pump some high pressure. It is so light weight, seems like it would work in your Alaska creeks. I converted mine from a 2 inch to a 2.5 inch. You can shove the hose down in the sand as about as fast as you can feed it to 6-7 feet deep. Once it hits hard bottom the artifacts and fossils start coming up. Dang Florida enviro laws have stopped such 'silting'. Man that thing vacuums out nooks and crannies. Still use it occasionally on private property.
Post by Deleted on Sept 30, 2014 7:51:47 GMT -5
Way to go Geoff. One of those nuggets probably beats my entire summer of prospecting. Jim
Post by mohs on Sept 30, 2014 7:52:08 GMT -5
excellent video healthy finds thanks for showing
Ed
spiritstone
Member since August 2014
Post by spiritstone on Sept 30, 2014 8:20:30 GMT -5
Looks like you had a great day with the highbanker! I noticed your using carpet instead of miners moss. I wondered if there was much of a difference between the two. I use the carpet myself.
