mikeinsjc
Member since June 2010
Post by mikeinsjc on Oct 10, 2014 23:39:23 GMT -5
Does anyone know where I can buy 24" diameter silicon carbide discs, 220 grit?
Post by Deleted on Oct 11, 2014 0:06:22 GMT -5
I can check check.
What kind of backing are you seeking?
Plain? Hook & loop? PSA?
What are you cutting?
I dont even know what's made but these are questions I ask clients before I get a quote from the mill.
Post by jamesp on Oct 11, 2014 7:10:22 GMT -5
mikeinsjc
Post by mikeinsjc on Oct 11, 2014 10:25:14 GMT -5
Shotgunner, I will use my 24" rotating flat lap to dry sand slabs off the saw prior to going on the Bull wheel. It doesn't matter if the backing is plain or PSA- no velcro as it will be going on a bare metal plate. Not sure if this will work, but anything has to be better than a vibrating lap for rough grind.
Post by Deleted on Oct 11, 2014 12:04:34 GMT -5
OK, I'll check my abrasives guys and see about price and availability.
If you can go with square/rectangle, then that is easy. 24" wide belts can be cut down.
