hornseeker
Member since January 2014
Post by hornseeker on Oct 12, 2014 22:49:30 GMT -5
Alright... I'll post pics soon and get rolling with this forum... but I do have a couple quick questions that I want to get answers to.
Started my first grind tonight!! I received my QT-66 with an extra 12# barrel a few days ago. I have a couple hundred pounds or so of pet wood and another 40-50 of Yellowstone agate that I have been antsy to get rolling! Well, tonight I filled the 12# barrel about 1/2 full, MAYBE a hair past 1/2. BUT... I think that barrel had to weight 20-25# once I got grit and water in it... Whats up with that?? Is is not supposed to be about 12# when appropriately loaded with rock. I COULD be wrong about the poundage, was just going by feel. I can weigh it though and see.
My other question is this... after just a few minutes that little motor feels hot. Is that normal??
One last question... the biggest rock I put in was much small than fist sized. I have a bunch of 1/2 to 1" diameter rock and a bunch varying from 1 inch to 2 1/2 inches. What is a max sized rock? Can I put a softball sized rock in there as long as there is a bunch of small stuff or maybe plastic pellets or ceramic to fill the space?
I took pics of the rocks before I put them in... and will post them probably tomorrow! Today I fished the Yellowstone and picked up about 25# of wood and agate!
thanks all!
HS
Steve
Member since June 2005
Post by Steve on Oct 12, 2014 23:07:51 GMT -5
A couple of quick comments:
You should be filling the barrel to just a bit over 3/4 th full with the water level at 3/4th.
It's normal for the motor to run hot.
I suspect that you're trying to tumble rocks that are too large without enough small Dr rocks as filler.
Generally you can only put in a few larger rocks in a load.
Post by quartz on Oct 12, 2014 23:08:46 GMT -5
You can run a rock as big as what you can put in the barrel, and still have some rolling room, say a couple inches smaller than barrel inside dia. Use a bunch of smaller stuff to give rolling and grinding action, plastic or ceramic is a waste of mtl. in the roughing stages. I've used pea gravel to fill up a barrel with one or two large pieces in it when I didn't have any small good stuff to run, or when I didn't want to chance the smalls getting broken. Agree w/Steve, 3/4 full is good, I skimp on the water though, less than to bottom of top layer of rock.
Steve
Post by Steve on Oct 12, 2014 23:09:37 GMT -5
Forgot to add: experimentation and "breaking the established rules" is an important part of tumbling.
hornseeker
Post by hornseeker on Oct 13, 2014 0:00:14 GMT -5
3/4 huh... even the directions say 1/2-2/3.... OK! Im fine with experimenting and breaking rules!!!
Thanks! And I'm glad to hear about the rock size, because I found a 6" diameter rock today that needs to be polished... not sure what it is, but I do believe it is some variation of chalcedony....
Thanks!
tkvancil
Member since September 2011
Post by tkvancil on Oct 13, 2014 8:38:34 GMT -5
All my Lortone tumblers weigh heavy when loaded. I go from 2/3rds to 3/4 full on all of them. I have found that they will work at 1/2 full but are slower to grind and you get more chipping.
The motor will be hot. This is normal.
In a 12# barrel loaded to 2/3rds I use 2 cups of water. Well below the bottom of the top layer guideline. Can't even see the water through the rocks without tilting the barrel.
I put in more than recommended large rocks quite often. Just be sure to have lots of smalls. Like Steve says experiment and see what works, Good Luck.
hornseeker
Post by hornseeker on Oct 13, 2014 10:14:59 GMT -5
Thanks!!! My next item on the wish list is that Lorraine combo saw/shaper! HS
hornseeker
Post by hornseeker on Oct 13, 2014 11:36:36 GMT -5
Lol. Spell checker!! Lortone!!
