Post by jamesp on Oct 14, 2014 17:07:11 GMT -5
This well was rated at over 500 GPM. That's all the compresser would blow out at full tilt.
Ave well depth in this area is 325 feet
This well 170 feet deep.
Ave GPM in this area 18 GPM
This one way over that.
Ave soil/clay depth 60'
This one 26 feet
Ave static head 35 feet
This one 22 feet.
Ave water bearing fissures 1-2
This one has 6
Ave draw down for 15 GPM pump at full speed is 12 feet
This one is 1 foot at 35 GPM
Pump is 35 GPM high pressure Predator pump.
The well driller set the pump and I hooked up the rest. Other well was a 2 inch well and had crappy water. this one sweet water.
Better water deposits in this area are in large round horizontal fractures in the hard granite, shaped like an upside down dinner plate
averaging 600 feet in diameter. Caused by soil being washed away for many years over flat granite bedrock.
Causing folds to lift 2-6 inches. Six inch diamond bit drills thru glass hard granite creating sand.
When bit drops at a fracture it breaks small chunks out of the ceiling of the fracture that get blown out of the hole.
The sound of the bit dropping a few inches and the resulting chunks are about a guarantee of water.
Old well pump went bad yesterday so 48 hour marathon to get this well hooked up.
30-50 PSI pressure switch, 30 gallon pressure tank, stolen from old well
Wife happy, me exhausted. Saved $1500. Spent $26 on wire and pressure switch, rest is used stuff.
Bypassing pressure switch pump powerful, sprays water 50 feet straight up out of a 3/4" garden hose.
Will install a big 25 GPM canon sprinkler on a tower to water a 1/2 acre front yard.
Well house is 6' X 6' X 3' industrial fan box of 1/8" steel.
Drought 3 years ago forced install. Straight wired pump and ran it 24 days straight to fill 3 irrigation ponds, over 1 million gallons
Nap time
This one 26 feet
This one 22 feet.
This one has 6
Nap time
