Roger
Post by Roger on Dec 14, 2014 1:37:43 GMT -5
My new saw arrived this week and I finally started slabbing again. I started off with some OJ First slab I faced one end and took 4 slabs, then cut two larger sections off. The color is great, but not many orbs =\ I will half the sections and cut smaller slabs from the opposite direction. I needed to get the width down to 7" so I could turn the stone and start cutting through the red/green/translucent area. I hope it has more orbs in that section. Before setting up the OJ for the other cuts, I slabbed some kaleidoscope jasper, ruby in fuschite, and some seraphinite. The saw cuts well and I am very happy with it
liz
Member since September 2014
Post by liz on Dec 14, 2014 7:14:19 GMT -5
Those are nice,what kind of saw do you have?
Post by snowmom on Dec 14, 2014 8:17:54 GMT -5
those look great, tell us more about the saw!
Post by Drummond Island Rocks on Dec 14, 2014 9:29:19 GMT -5
No picture of the saw? nice cuts. that seraphinite looks great.
Post by Fossilman on Dec 14, 2014 9:56:25 GMT -5
Heck ya',that's a great start!!!
Post by iant on Dec 14, 2014 11:42:03 GMT -5
Nice material! Always good to find a new purchase works like it should.
Post by deb193redux on Dec 14, 2014 15:19:07 GMT -5
also curious about the saw. several very nice kalidoscope there too.
Post by jamesp on Dec 14, 2014 21:47:38 GMT -5
Broke that saw in right
Post by Starguy on Dec 14, 2014 22:19:38 GMT -5
@roger
I'm in the market for a slab saw. What did you get? I've been looking at a 16" Covington. Give some details on what size rocks yours will cut.
Great colors on the OJ. Those slabs look great. Thanks for posting photos.
Later
Brent
Roger
Post by Roger on Dec 14, 2014 23:21:34 GMT -5
Starguy deb193redux liz snowmom Drummond Island Rocks
I went with a Covington 16" with power-feed. I made the purchase on ebay from Jodi Boyd, aka "theagateer". For the record - Jodi is awesome. One of the nicest and most sincere people I have run across in a very long time.
The saw is pretty nice. I like the compact design quite a lot. I had an 18" for a little while and the thing was huge. This saw tucks away in a corner nicely and is compact enough for me to lift it if I need to.
My two "complaints" with at this point are; 1) It is a loud saw. The 18" I had was quiet enough when cutting hard agate to carry on a conversation standing beside it. The Covington, not so much. 2) It does leak some oil mist/vapor. Not a lot, but enough to see it. Otherwise, the saw is perfect for me.
The vice will open to a bit over 7" wide. I think it will cut 6.5"Hx7"Wx18"L.
Saw loaded with OJ
Saw tucked into the corner and my messy cab area..I need to reorganize it again lol
The other half the messy cab area..
Post by captbob on Dec 15, 2014 0:01:15 GMT -5
Sweet! Been waiting for the saw pictures as well. It's SO clean!! Where is the "messy" cab area? Looks kinda normal to me. Hope you don't need in that breaker box in a hurry sometime. I don't think I would be comfortable having a rock sit that far out from the vise. Hope we can look forward to more slab pictures now
Roger
Post by Roger on Dec 15, 2014 0:21:13 GMT -5
I don't think I would be comfortable having a rock sit that far out from the vise. With raw rough, I wouldn't hang it out like that. I had just faced both sides of that rock so there were smooth sides for the vice to hold onto. I tightened it down well and made sure there was zero movement...then I baby-sat the first slab and double-checked it was all still tight before starting the next.
Post by snowmom on Dec 15, 2014 6:53:02 GMT -5
wonderful setup! keep the slabs coming now!
Post by deb193redux on Dec 15, 2014 10:45:48 GMT -5
that's a lot of height for a 16"
what size flange?
Post by johnjsgems on Dec 15, 2014 12:36:54 GMT -5
Covington is known for undersizing flanges to gain more cutting height. Flange should be minimum 1/6 blade diameter per MK.
Roger
Post by Roger on Dec 15, 2014 13:33:03 GMT -5
I think the flanges exceed the minimum suggestion from MK. I believe they are 3". I would need to check and verify it though.
Post by deb193redux on Dec 15, 2014 13:45:03 GMT -5
I think 3" is better for blade stiffness anyway. Still, 8-3 suggests 5" height. All in all a nice range of sizes you can handle. Looks like plenty of space to the right of the vise too.
Post by Starguy on Dec 15, 2014 19:27:19 GMT -5
@roger
Sweet.setup. What kind of cabbing unit is that? I've never seen one with 8 wheels. Do they make an 8" unit? Thanks for showing.
later
Brent
Post by Deleted on Dec 15, 2014 21:07:20 GMT -5
Actually a 3" flange will eat up 1-1/2" of the 8" blade height, giving well over a 6" cut height. Roger, that is really awesome all the way around!
Post by Rockoonz on Dec 15, 2014 21:56:48 GMT -5
Nice shop setup. Your messy is cleaner than my cleaned up. I am curious about the 8 wheel unit too.
