Post by broseph82 on Jan 6, 2015 16:54:46 GMT -5
Obsidian and slag snowmom sent me And my own slag piece (the very first piece my wife and I found) And a piece of filler glass dry: And wet: jamesp I'm guessing I need to order a prepolish from the rockshed? This stuff was in polish for 5 days. I want it better! Polish stage I didn't have enough filler glass and bowl was only 1/2full. Def need some more soft media for slag and obsidian besides glass.
Post by jamesp on Jan 6, 2015 17:06:40 GMT -5
For glass and obsidian I did 500 1000 and then Rock Shed 1 micron polish. And used all small glass filler. Looks like the edges of the blue glass polished, but not the center flat area. Darn good tumble. Way to go. I think it is not good to have the barrel 1/2 full, not sure. And different glass takes different polishes.
You scored well, snowmom's stuff is fine
Post by broseph82 on Jan 6, 2015 17:36:15 GMT -5
For glass and obsidian I did 500 1000 and then Rock Shed 1 micron polish. And used all small glass filler. Looks like the edges of the blue glass polished, but not the center flat area. Darn good tumble. Way to go. I think it is not good to have the barrel 1/2 full, not sure. And different glass takes different polishes. You scored well, snowmom's stuff is fine You're right about it being bad to have 1/2 full. I def got pits and bumps in the polish stage from not having enough filler. My filler also broke down a ton! I also took out some slag that needs to be ground down and pit free and that took a nice bulk out of my media. I thought I was getting the 1000 grit in my grit pack, but maybe I'll just let my 500 go for more than a day each charge. The polish is actually really nice, but like I've read here still has a matte look in certain angles. Not too bad for my first real vibe tumble though. Thanks for your input! What's the difference between my AO polish I got and the 1 micron?
Post by Jugglerguy on Jan 6, 2015 17:47:31 GMT -5
Those look good, Bro. I can't remember, did you rough them in a rotary, or did they go into the Lot-O from the beginning? I think the Lot-O can actually be damaged by not running it full, plus the action isn't as good.
Post by broseph82 on Jan 6, 2015 18:02:53 GMT -5
Those look good, Bro. I can't remember, did you rough them in a rotary, or did they go into the Lot-O from the beginning? I think the Lot-O can actually be damaged by not running it full, plus the action isn't as good. These weren't rotaried. I still have those going. The action was good when it was almost full, but when it came down to polishing and me pulling stuff out it def wasnt near as full as it was. Will have to have stuff ready for each stage sitting by. Off to a bar that's close to ask for beer bottles
Post by jamesp on Jan 6, 2015 18:33:42 GMT -5
Those look good, Bro. I can't remember, did you rough them in a rotary, or did they go into the Lot-O from the beginning? I think the Lot-O can actually be damaged by not running it full, plus the action isn't as good. These weren't rotaried. I still have those going. The action was good when it was almost full, but when it came down to polishing and me pulling stuff out it def wasnt near as full as it was. Will have to have stuff ready for each stage sitting by. Off to a bar that's close to ask for beer bottles Rob is right. Hard to tell if it is operating properly, if the vibrations are slightly off it will damage your rocks and hinder polish. If it was half full there should be problems. They are tuned for a given amount of rocks.
Post by fantastic5 on Jan 6, 2015 18:48:52 GMT -5
Great first run Jimi! I've only done tears, haven't gotten brave enough for full size obsidian. Nicely done
Post by pghram on Jan 6, 2015 21:25:18 GMT -5
+1 to "nicely done" really outstanding.
Rich
Post by Drummond Island Rocks on Jan 6, 2015 21:32:35 GMT -5
Congrats. Have fun with your new toy. My biggest piece of advice is to invest in some ceramic to keep your loads balanced through the whole process. There are times when I will tumble a handful of cabs with 3.5 pounds of ceramic.
Post by snowmom on Jan 7, 2015 5:50:01 GMT -5
those look good!
Post by broseph82 on Jan 7, 2015 8:12:54 GMT -5
Great first run Jimi! I've only done tears, haven't gotten brave enough for full size obsidian. Nicely done You can get obsidian for 1-3 dollars a pound if you look on eBay or even here from Tony. I cut some last night and may throw some in the tumbler soon.
matt2432
Member since December 2014
Post by matt2432 on Jan 7, 2015 9:28:47 GMT -5
Some nice looking pieces. I like the amber colored slag
tkvancil
Member since September 2011
Post by tkvancil on Jan 7, 2015 11:56:30 GMT -5
Nice stuff, well done. I'm with Chuck get some ceramics. Very good filler for the vibe.
Post by broseph82 on Jan 7, 2015 19:38:24 GMT -5
Nice stuff, well done. I'm with Chuck get some ceramics. Very good filler for the vibe. I have some ceramic triangles from HF that I used in my rotary, but not enough for the vibe so I went to TRockshed and ordered a 5lb bag of small ceramic and a 5lb bag of pellets for polish. I thought I didnt have prepolish, but my 500grit IS prepolish.
Post by Fossilman on Jan 8, 2015 15:21:57 GMT -5
Very nice!
