Post by vegasjames on Jan 11, 2015 5:39:49 GMT -5
Post by snowmom on Jan 11, 2015 6:26:39 GMT -5
absolutely gorgeous!
Post by Sabre52 on Jan 11, 2015 8:04:05 GMT -5
Wow! That's a beauty. How do you install the pins? You can't pound them in right? Do you slip them in, glue them, and file them off or what?.....Mel
Post by gingerkid on Jan 11, 2015 14:59:40 GMT -5
Thunder69
Thunder 2000-2015
Post by Thunder69 on Jan 11, 2015 16:21:18 GMT -5
Damn that's nice...Excellent work on the handle ...Where did you find the blade....John
Post by vegasjames on Jan 11, 2015 16:24:32 GMT -5
Wow! That's a beauty. How do you install the pins? You can't pound them in right? Do you slip them in, glue them, and file them off or what?.....Mel Thanks Mel. I found some brass rid at Lowe's that fit the holes in the knife blank holes perfectly. I drilled the holes in the stone with a masonry bit the same size. Then I applied a little epoxy to the rod end and put it in the hole. I lightly tapped the end of the rod against the ground to drive it through then cut off the rest of the rod with a hacksaw. Then ground the rod flat to the stone with an angle grinder with a diamond pad. Then more polishing with a finer diamond pad and hand sanding with sanding sponges and super fine wet/dry sandpaper and water.
Post by vegasjames on Jan 11, 2015 16:25:20 GMT -5
Thanks, Smowmom and Gingerkid.
Post by vegasjames on Jan 11, 2015 16:29:57 GMT -5
Damn that's nice...Excellent work on the handle ...Where did you find the blade....John Thanks John. I bought various knife blanks on Ebay. I don't recall the name of the seller.
barclay
Lowly Padawan of rocks
Post by barclay on Jan 13, 2015 9:26:16 GMT -5
The blank looks like it came from Premium Knife Supply. That is where I get my blanks. With some patience you can get a much better price buying from them on ebay than if you go to their website.
NDK
Post by NDK on Jan 13, 2015 16:58:15 GMT -5
Awesome knife. The scales look great. I like the finish on the blade too, is that blued?
Post by glennz01 on Jan 13, 2015 17:29:38 GMT -5
the blade almost looks like obsidian
Post by Deleted on Jan 13, 2015 18:56:04 GMT -5
I like the way you jigged the blade. Old school it was the handles that got jigged (bone). Seems like a nice blade treatment for a hunter too!
Woot!
Post by vegasjames on Jan 13, 2015 19:14:31 GMT -5
Awesome knife. The scales look great. I like the finish on the blade too, is that blued? Not sure what the finish is. I bought it that way and they did not specify how the finish was done. As I get more in to this I want to start experimenting with different finishes including trying to etch the metal in the same way I do my iron meteorites to see what it will do with the metal. I will practice on the handle part first to see what it looks like. That way if it does not turn out well then at least it will be hidden under the scales.
Post by gingerkid on Jan 14, 2015 11:38:08 GMT -5
Why not make a meteorite knife, vegasjames? I read one website that uses meteorite shavings to make the blade. Do you know the process?
Post by vegasjames on Jan 14, 2015 18:41:03 GMT -5
Why not make a meteorite knife, vegasjames? I read one website that uses meteorite shavings to make the blade. Do you know the process? Never heard of using shavings. I have seen blades made from slabs of iron meteorite. But you have to have one large enough to cut in to a blade, and iron meteorites can be quite costly. At least the more stable ones. Nantans are cheap but notorious for rusting. Gibeons are very popular and have a great etch pattern and don't rust quite as easily. But Africa has banned exporting of these so the price has jumped to around $5+ a gram. And keep in mind now many grams you will lose in cutting and grinding. Dronino would make a really cool blade with its golden iron pyrite inclusions. But that would be a problem with the sharp edge of the blade. The next problem is that they are very hard to cut. Iron meteorites can tear apart diamond blades very easy. Generally they are cut with carbide blades and at an extremely slow rate. I have never forged but a possible issue with shavings would be the different melting points. The story behind the discovery of the Nantan meteorites discovered in China is when people were gathering iron rocks for smelting to make steel. When the meteorites were added to the smelter they did not melt like the rest of the iron ore.
Post by gingerkid on Jan 15, 2015 6:40:01 GMT -5
Post by gingerkid on Jan 15, 2015 7:14:33 GMT -5
Post by vegasjames on Jan 15, 2015 7:40:11 GMT -5
Thanks, interesting. I like the label on the meteorite shavings bottle where it says "not for eating".
Post by gingerkid on Jan 15, 2015 8:07:11 GMT -5
ROFL, had to take another look at the label, vegasjames. You're welcome for the links, and hope you find a way to create a meteorite knife. James, in ancient times, they believed that ingesting ground diamonds helped cure stomach disorders. www.nanomedicine.com/NMIIA/15.1.1.htm
Post by vegasjames on Jan 15, 2015 8:18:04 GMT -5
Probably would not be a good idea to eat the meteorite shavings anyway with all the nickel in it. Many people have nickel allergies.
