Post by phil on Jan 22, 2015 17:25:48 GMT -5
Hi all, I have about 15 5 - 8 inch diameter, 3 inch wide, 1 inch bore Lever Lock or Split Rim polishing wheels to gt rid of. New, these cost $65 at Covington engineering. I'm asking $20 each. I can get one in a medium flat rate USPS box, or 2 in a large USPS flat rate box. Postage not included in my price, sorry. Here's what Covington says about them: "Lever-Lock Drums are made of sturdy cast aluminum and balanced to reduce vibration. The 3" rim is covered with sponge rubber. The lock area is threaded for setscrew-operated clamp, just loosen to remove the old cloth and retighten to secure the new." For their complete info, go to: Covington's infoThanks! Phil And here are some pics: Thanks again!
Post by gingerkid on Feb 8, 2015 9:25:23 GMT -5
Thanks again, phil! Phil went out of his way and placed a belt on the lever-lock drum for me, which I greatly appreciate. He also added some beautiful travertine rough to the box for me to wreak havoc upon. This is the second time I've purchased lapidary goodies from Phil, and I highly recommend his goods!
Post by broseph82 on Feb 12, 2015 14:07:51 GMT -5
I got a wheel but no travertine :-( Guess pretty people get all the free stuff. Thanks again phil
Post by phil on Feb 12, 2015 14:17:59 GMT -5
She's pretty too? Dang, wish I'd have known..... <big grin> You had but to ask... She was looking for beginners rock, and I had some that was perfect. I just posted a trade offer for my lolly rock, but if you'd rather trade for travertine/opalite, can do that too....
Post by broseph82 on Feb 12, 2015 17:42:15 GMT -5
phil what grit was on the wheel you sent me?
Post by phil on Feb 12, 2015 19:56:21 GMT -5
Unknown, but I'd guess about 220.
Post by broseph82 on Feb 15, 2015 20:25:50 GMT -5
do they make felt that I can put on this? phil or just those expensive diamond belts? For polishing anyway. Id like to use this just for polishing
39don
https://www.etsy.com/shop/DonsLapidaryArts
Member since February 2012
Post by 39don on Feb 15, 2015 20:47:41 GMT -5
I to have purchased 2 wheels from Phil and they are right on and brand new!!!!!!!! I'm going to coat them with my homemade diamond compound eventually but I ran up on a used 3" wide 220grit 3M diamond belt which made me 3 belts for the 8" thumper's. I don't mind the thumping.
Phil had mine covered covered too so I had a great pattern to start with. Thanks Phil..............
39don
Post by phil on Feb 15, 2015 21:33:25 GMT -5
do they make felt that I can put on this? phil or just those expensive diamond belts? For polishing anyway. Id like to use this just for polishing I don't really know. We'd need to measure the circumference and then try and find a belt..... You could always just buy some felt at the fabric store and cut to fit? I think there's room to fit it in the lever slot....
Post by phil on Feb 15, 2015 21:34:46 GMT -5
I to have purchased 2 wheels from Phil and they are right on and brand new!!!!!!!! I'm going to coat them with my homemade diamond compound eventually but I ran up on a used 3" wide 220grit 3M diamond belt which made me 3 belts for the 8" thumper's. I don't mind the thumping. Phil had mine covered covered too so I had a great pattern to start with. Thanks Phil.............. 39don Welcome! Broseph - you might try this with some store bought heavy felt? Check at a reupholstery store for the heavy stuff.
Post by jakesrocks on Feb 15, 2015 23:22:19 GMT -5
For heavy felt, try a place that does repairs on motor homes. They use a heavy, almost 3/16" thick synthetic felt to line the outside storage cabinets. It's great for polishing. It'll be way too thick to fit in the slot, so why not use feathering cement and glue a band all the way around ?
Phil, gotta check to see how many bump wheels I have. I may need to get a couple from you.
TByrd
Have you performed your random act of kindness?
Member since December 2010
Post by TByrd on Feb 16, 2015 0:41:11 GMT -5
What kind of belts do those take? Do you have any left?
Post by phil on Feb 16, 2015 1:02:55 GMT -5
For heavy felt, try a place that does repairs on motor homes. They use a heavy, almost 3/16" thick synthetic felt to line the outside storage cabinets. It's great for polishing. It'll be way too thick to fit in the slot, so why not use feathering cement and glue a band all the way around ? Phil, gotta check to see how many bump wheels I have. I may need to get a couple from you. They've been selling on my ebay. Only have 5 left. But if you want more, I can ask my source if she has any more left. I got these at this price because she wants to get rid of them.
Post by phil on Feb 16, 2015 1:05:26 GMT -5
What kind of belts do those take? Do you have any left? Wheels, yes, 5 left. Belts, none. But you can buy the various grits by the roll at Covington for sure and possibly other lapidary shops. I didn't buy any belting, just the wheels to convert into homemade 3 inch wide diamond wheels.
Post by jakesrocks on Feb 17, 2015 16:45:52 GMT -5
Post by Fossilman on Feb 17, 2015 18:20:30 GMT -5
I just changed out two old bump wheels to expando wheels...They were in rough shape too....
Post by phil on Feb 17, 2015 22:32:03 GMT -5
Convert them to Diamond!
