Post by Deleted on Feb 15, 2015 19:28:09 GMT -5
Ya'll have seen this cab before. I left the stone in the shape and thickness that it was when I acquired it so the variation in thickness made it tough to figure out a way to hang it. I did not want to drill it so after much thought :idea1: I decided to do a half groove wrap which my guess would be unique to the planet (maybe, I have not covered the whole planet YET) I am sure that most of you have figured out that, right or wrong, I ALWAYS try to do things a little different. It is unfinished and I am trying to decide which way to finish it. I buy every cord and wire that is different than what I have so I ended up with this 16 gauge soft brass wire. It is too small for the groove so I plan to wrap it with silver wire. Here are some different options for wrapping the wrap. Top center: 30 ga wire Left around: 28 ga wire. perfect fit in groove. 26 ga wire. Too big for groove Crimped wire. Too big for groove but I like the look. Half round wire first wrapped inside out then outside out. Outside out is good fit and look. I will probably go with the 28 ga argent wire because when I go around the curves it does not leave a wide gap so the brass can be seen. I have experimented and I can wrap on the long straight part then push the wrap over the loops. When I get it all wrapped I will use epoxy in the holes to hold everything in place. It is difficult to get the wire off now so I have no worries about it coming off when worn. My biggest concern is a reaction between the two different metals over time. Jim
Post by snowmom on Feb 15, 2015 20:39:10 GMT -5
the brass is very complimentary to that cab, clever presentation, watching with interest.
39don
https://www.etsy.com/shop/DonsLapidaryArts
Member since February 2012
Post by 39don on Feb 15, 2015 21:12:33 GMT -5
Ya'll have seen this cab before. I left the stone in the shape and thickness that it was when I acquired it so the variation in thickness made it tough to figure out a way to hang it. I did not want to drill it so after much thought :idea1: I decided to do a half groove wrap which my guess would be unique to the planet (maybe, I have not covered the whole planet YET) I am sure that most of you have figured out that, right or wrong, I ALWAYS try to do things a little different. It is unfinished and I am trying to decide which way to finish it. I will probably go with the 28 ga argent wire because when I go around the curves it does not leave a wide gap so the brass can be seen. I have experimented and I can wrap on the long straight part then push the wrap over the loops. When I get it all wrapped I will use epoxy in the holes to hold everything in place. It is difficult to get the wire off now so I have no worries about it coming off when worn. My biggest concern is a reaction between the two different metals over time. Jim I don't think you will have a problem with the metals having a reaction. I know you are aware most metals major reactions are to moisture and abrasion. Keep the pendant in a wooden jewelry box or plastic ziplok for moisture and the major wear will be negligible inside of the eyes. Very neat idea on your wire wrapping!!!!!!!!!!!!!!
Post by Deleted on Feb 15, 2015 22:15:09 GMT -5
the brass is very complimentary to that cab, clever presentation, watching with interest. Yes, I like the brass with the stone too but I would have concerns with contact of bare brass and skin. It will cause a reaction with some people so the exposed brass wrap will have to wait for another time. Jim
adrian65
Member since February 2007
Post by adrian65 on Feb 16, 2015 0:16:24 GMT -5
Brilliant idea! Groovy grip.
Adrian
Post by Pat on Feb 16, 2015 0:25:48 GMT -5
Jim, that's classy. I like it a lot. Good looking stone, too. You are on a roll!
Post by Deleted on Feb 16, 2015 7:14:33 GMT -5
Jim, that's classy. I like it a lot. Good looking stone, too. You are on a roll! hahaha Thanks Pat but the truth is I am bored to tears so my mind is scattered all over the place trying to unbore me. I must have ten projects going and I am jumping from one to the other. I even drilled a couple of ring blanks which I have not done in forever. You will be tagged in one of those when finished. And thanks all for the great compliments. It means a lot. Jim
Post by rockjunquie on Feb 16, 2015 11:15:21 GMT -5
Jim, I LOVE that you are always trying new things. You never seem to run out of ideas! You always seem to strike gold and this is no exception. I like it! : ) Keep up the great work!
Post by Deleted on Feb 16, 2015 15:09:14 GMT -5
I wrapped what seemed like a mile of wire on the brass wire, got it all nice and neat and I DO NOT LIKE IT. The brass looks good with that stone and I think I need to go back to it. I have some smaller brass wire so I am going to try a three wire twist and do the same style of wrap as before. Time wise this pendant is working up to being priceless but I really like this stone and I want it right. If I have to I can put the silver back on but I doubt that I will need to. Jim
Post by rockjunquie on Feb 16, 2015 17:30:43 GMT -5
I wrapped what seemed like a mile of wire on the brass wire, got it all nice and neat and I DO NOT LIKE IT. The brass looks good with that stone and I think I need to go back to it. I have some smaller brass wire so I am going to try a three wire twist and do the same style of wrap as before. Time wise this pendant is working up to being priceless but I really like this stone and I want it right. If I have to I can put the silver back on but I doubt that I will need to. Jim Hey dude! Don't give up on the coiling yet! It looks really awesome with LOS. What kind of metal is it again??? You can probably use the liver of sulfur. If you haven't used it, give it a try- super easy to use. It will make a huge difference. I think you will like it with this.
Post by Deleted on Feb 16, 2015 18:40:13 GMT -5
rockjunquie I have heard of the liver of sulfur but I have not been able to get my liver to cough any up. Okay, bad joke. Do you have a photo of the results on silver. The wire spool says Plated Argent non tarnish silver so I am not sure if I can tarnish it. Jim
Post by rockjunquie on Feb 16, 2015 23:41:27 GMT -5
rockjunquie I have heard of the liver of sulfur but I have not been able to get my liver to cough any up. Okay, bad joke. Do you have a photo of the results on silver. The wire spool says Plated Argent non tarnish silver so I am not sure if I can tarnish it. Jim No, you won't be able to LOS the coated (non tarnish) wire. I've done a lot of pieces with a patina. Here's an old silver piece with LOS. It brings out the texture in a wrap and makes the silver richer, I think, and less chrome looking.
Post by Deleted on Feb 18, 2015 0:10:16 GMT -5
I found some smaller brass (fake gold) wire that was small enough to twist three wires together and have it fit into the groove perfectly. Twisted some up. Shaped it and somebody made it too short. I made the loops a little smaller to get enough wire to make it to the hole and finished it up. I glued the ends in because I planned to give it to my grand daughter today. At the last minute I decided to take three cabs and let her choose which one she wanted. She chose a different one so I still have it but someone has offered to buy it with the silver wrapped brass. Guess I will be drilling out the brass and going back to silver. Sheesh times ten. I am going to be glad when this thing is gone Jim
Post by Fossilman on Feb 18, 2015 11:09:53 GMT -5
Hell ya' Jim!!!! Thumbs up
39don
Post by 39don on Feb 18, 2015 11:40:34 GMT -5
That's one you will always remember, Jim!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I liked both the brass and silver. Hard to choose but the brass match's the cab better.
39don
Post by rockjunquie on Feb 18, 2015 12:11:40 GMT -5
I think I like the brass best.... gold would be even better. : ) When you get this finished, you will always look on it and remember the work that went into it. Those are generally the most satisfying... when they turn out well, that is, and yours will.
Have I mentioned how much I like that stone??? Nice one!
Post by Pat on Feb 18, 2015 12:11:55 GMT -5
Jim, that's terrific!
Post by Deleted on Feb 27, 2015 10:02:50 GMT -5
I forgot to mention that I sold it on another forum with the silver wrapped on the brass. She is happy, I am happy.
Pat, I still do not know what the stone is. Probably won't ever know unless shotgunner comes up with an answer. Jim
