Post by phil on Mar 19, 2015 20:32:05 GMT -5
If you could redesign a drop saw similar to The Lortone series 14 and 16 inch saws, or even the old Gemstone drop saws, what changes would you make? I've modified mine to include a drain and handles, and added a base. What would you change? (and if you've already done it, can you post a pic?)
Thanks! Phil
Post by Rockoonz on Mar 19, 2015 20:50:50 GMT -5
I would add a hydraulic cylinder like a screen door cylinder with speed control to set the rate of speed with smaller sections of rocks. I haven't done it and probably won't, don't have a drop saw.
Post by Sabre52 on Mar 20, 2015 7:38:25 GMT -5
Lortones have a pathetic coolant pumping system that needs replacing and they need some kind of an adjustable added weight system cause they often don't feed worth spit. Also need a good tray for coolant that has a drain plug so you don't have to lift the whole dang saw from the tray to clean it properly......Mel
Post by phil on Mar 20, 2015 12:13:40 GMT -5
Yeah, pretty much figured those out already, plus an enclosure, but was wondering if anyone had any other good mods. Thanks!
