Post by 1dave on Mar 24, 2015 18:31:43 GMT -5
From my friend Betty:
1. Brinicles are the underwater equivalent of icicles.
They form beneath ice when a flow of saline water is introduced to ocean water.
2. Volcanic lightning
Volcanic plumes produce immense amounts of electrical charge and
static. In rare cases, this can spark a violent lightning storm.
3. Sprites, Elves and Blue Jets
These colourful shapes are the result of electrical discharges in the atmosphere.
4. Fire Rainbows
Fire Rainbows are formed by light reflecting from ice crystals in high
level clouds. The halos are so large, they often appear parallel to the horizon.
5. White rainbows
These rainbows form in fog, rather than rain. The condensation reflects
little light, and as a result, the rainbow is made up of very weak colors –
like white – rather than the vibrant colors of a traditional rainbow
6. Fire Whirls
Fire whirls are whirlwinds of flame. They occur when intense heat
and turbulent wind conditions combine.
7. Catatumbo Lightning
At the mouth of the Catatumbo River in Venezuela, a very unique mass
of storm clouds swirl, creating the rare spectacle known as Catatumbo
lightning. The storm occurs up to 160 nights a year, 10 hours per day
and 280 times an hour.
8. Moonbow
Moonbows are rainbows produced by light reflected off the surface of
the moon, rather than the sun. Due to the small amount of light
reflected off the moon,moonbows are quite faint.
9. Glory
A glory is an optical phenomenon, similar to a rainbow, that
resembles a halo. It occurs when light tunnels through air inside
rain droplets and emit the light backwards. Yes, that’s as crazy as it sounds
10. Waterspouts
Waterspouts are vortexes, which occur over a body of water.
No water is sucked in and the sprout is made entirely from water given off by condensation.
11. Morning Glory
Morning Glory clouds are incredibly rare, so much so, that we don’t
know what causes them. They’re most commonly seen at fall in the
small town of Burketown in Australia.
12. Lenticular Clouds
Lenticular clouds are lens-shaped clouds that form when moist air flows
over a mountain and piles into large and layered clouds. Due to their
strange shape, these clouds are often mistaken for UFOs.
13. Penitentes
Penitentes are tall, thin blades of hardened snow and ice that form at
high altitudes. At such a height, the sun’s rays are able to turn ice
into water vapor without melting it first. Some areas randomly turn into
vapor more quickly than others, forming depressions in the smooth
surface. Over time, they transform into jagged fields which face the
same direction as the sun.
14. Supercells
Supercells are the rarest and most dangerous type of storms. While
they are formed just like other storms, the vertical rotation of their
updraft means that they can sustain themselves for far longer.
15. Frost Flowers
Frost flowers are formed when sap in the stem of plants freezes and
expands, cracking the stem. Water then draws through the cracks
and freezes upon contact with the air, eventually forming exquisite
patterns.
16. Sun Dogs
Sun dogs are an atmospheric phenomenon that occur when ice
crystals cause light to appear brighter when the sun is at a certain angle
17. Mammatus Clouds
Mammatus clouds are cloud pouches that form and hang underneath
the base of a cloud. When air and clouds holding different levels of
moisture mix, the heavier one sinks below the lighter.
18. Snow Donuts
Snow donuts are formed when chunks of snow are blown along the
ground by wind, picking up material along the way. The inner layers
are weak and can easily blow away, leaving a donut.
19. Belt of Venus
The Belt of Venus is a pink glowing arch seen across the sky when the
shadow of the Earth’s translucent atmosphere casts a shadow back
upon itself.
20. Asperatus Clouds
Asperatus Clouds were only classified in 2009. As a result, we know little about
them other than the fact that they look amazing.
4. Fire Rainbows
5. White rainbows
6. Fire Whirls
8. Moonbow
9. Glory
10. Waterspouts
11. Morning Glory
13. Penitentes
14. Supercells
15. Frost Flowers
patterns.
16. Sun Dogs
17. Mammatus Clouds
18. Snow Donuts
19. Belt of Venus
upon itself.
