NDK
Post by NDK on Mar 28, 2015 6:42:39 GMT -5
This is the 1st cab off my new machine. It's not perfect, but since I didn't see the fracture til I was done I'm gonna leave it as is. Thanks for lookin.
Post by Fossilman on Mar 28, 2015 9:27:56 GMT -5
Hey,I like that-Thumbs up...................
Post by Deleted on Mar 28, 2015 12:16:48 GMT -5
Feathers sticking out of a gourd. Sweet. Jim
Post by stardiamond on Mar 28, 2015 22:33:31 GMT -5
Montana and factures (healed and unhealed) go together a lot of the time. Tahoma and Morgan Hill also. If you get a good scene, like your cab, it's worth the effort.
NDK
Post by NDK on Mar 28, 2015 22:44:16 GMT -5
It's pretty thin, hopefully it holds together. Was a 1 cab wonder slab that I got in an old collection at an auction. It worked out perfect for that shape.
Post by stardiamond on Mar 28, 2015 23:00:19 GMT -5
I've got 5 pounds of Montana nodules arriving next week. Great slabs are too expensive and the rough is like the box of chocolates line from Forrest Gump. It's and adventure from slabbing to cabbing.
Post by gingerkid on Mar 29, 2015 12:08:14 GMT -5
Your Montana pick looks awesome, NDK, and your new machine did a sweet job! Are you enjoying your machine and have you done any other modifications to it?
NDK
Post by NDK on Mar 29, 2015 12:36:40 GMT -5
Thanks Jan. I exchanged the motor I had on there for the 1 I planned to use & wired it with a ground as 1dave suggested. I've been planning to figure out drains for the hoods, but every time I get the few pieces needed they won't work quite right. I think I finally have it figured out, so a trip to the store one last time should do the trick.
Post by mohs on Mar 29, 2015 12:50:40 GMT -5
That will look great sloping down someone's neckline ! mohson
Post by gingerkid on Mar 30, 2015 13:58:25 GMT -5
My apologies for straying off topic, NDK, but I wanted to ask if you will please update your cabbing machine thread with any modifications you make to it when you can? I exchanged the motor I had on there for the 1 I planned to use & wired it with a ground as 1dave suggested. I've been planning to figure out drains for the hoods, but every time I get the few pieces needed they won't work quite right. I think I finally have it figured out, so a trip to the store one last time should do the trick.
NDK
Post by NDK on Mar 30, 2015 18:23:57 GMT -5
When I get it finished I'll happily update it, Jan.
