lparker
Member since March 2008
Post by lparker on Mar 28, 2015 13:50:54 GMT -5
Will oxalic acid eat stainless steel? I'm getting some dirty quartz next week. Thought that after I pressure wash them, I'd put them in a stainless pot on a turkey fryer to keep it warm.
Lee #1
Post by jakesrocks on Mar 28, 2015 16:18:03 GMT -5
From my own experiences, oxalic will frost & discolor stainless, but I don't think it will eat holes in it.
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Mar 28, 2015 16:48:06 GMT -5
I'd suggest using something non-reactive, like glass or acid safe plastic. wear chemical glasses and gloves and be in a well ventilated area. If you're going to dilute it, remember add acid to water, never the reverse.
Post by orrum on Mar 28, 2015 16:51:30 GMT -5
Old crock pot.
lparker
Post by lparker on Mar 28, 2015 18:04:54 GMT -5
crock pot will be too small - anyway my wife won't let me use it Hard to keep plastic or glass warm. I'll be soaking on my deck so ventilation won't be a problem. So it looks like I'll be using my old brew pot - 3-4 gallon size. I'll be getting maybe 60-80 lbs of crystals next week. If I like what I get, I'll be getting 700-900 lbs more - need a high volume soaker Thanks, Lee #1
Thunder69
Thunder 2000-2015
Post by Thunder69 on Mar 28, 2015 19:55:17 GMT -5
Lee I use a plastic tote with Iron Out.. mix it up and cover the tote with the lid and letit sit..About 12 hours check them and give the tote a shake to remix it (The Iron Out will settle ).let them sit overnight, if they look good, Give them a good rinse with a pressure hose and they will shine... John
Post by jakesrocks on Mar 28, 2015 20:30:28 GMT -5
Gotta love yard sales. I use yard sale crock pots & roasters. Keeps me out of trouble with the wife. With a little luck you may find a turkey roaster in a yard sale. For crock pots and roasters, use those with a removable ceramic insert. Set them at the warm setting. They don't have to be boiling hot to do the job.
Post by snowmom on Mar 29, 2015 6:51:57 GMT -5
goodwill and salvation army or other resale stores usually have crock pots for next to nothing... this thread has lots of good info. lparker, can't wait to see what you cook up!
Post by 150FromFundy on Mar 29, 2015 11:20:40 GMT -5
I have dissolved the bottom out of a cheap stainless steal pan with Iron Out. Not too much nickel in cheap stainless, or the stainless was only a plate, and the acid attached the metal through a scratch.
If you can get a hold of one, you need a 45 gallon barrel, many of which are made out of HDPE plastic. Many companies ship chemicals in them and will sell the empty barrels for as low as $5 or $10 to get rid of them.
I get mine from our local water treatment plant who receives chemicals in them.
Darryl.
lparker
Post by lparker on Mar 29, 2015 12:17:24 GMT -5
yeah, but how do you heat the solution and keep it warm when using plastic? I don't live in SoCal. I got plastic barrels.
Lee #1
Thunder69
Thunder 2000-2015
Post by Thunder69 on Mar 29, 2015 12:22:00 GMT -5
Lee I will have to look for my before and after pics.... I didn't use heat just kept it in the sun for the day.. John
lparker
Post by lparker on Mar 29, 2015 18:34:19 GMT -5
but you have SUN down there I've been to LA before and I've SEEN it. I changed my plan. Heat the water on the turkey fryer and dump it in the plastic barrel...at least I'll get a warm start. I've read that oxalic acid works faster warm. Lee #1
Thunder69
Thunder 2000-2015
Post by Thunder69 on Mar 29, 2015 18:34:36 GMT -5
lparker
Post by lparker on Mar 29, 2015 18:35:54 GMT -5
Nice! Now I know what to look forward to.
Post by Rockoonz on Mar 30, 2015 0:45:53 GMT -5
I use a large glass coffee pot on a hot plate at the lowest setting. I think stainless won't last long with oxalic acid and the nickel and whatever else released as the pan corrodes may discolor your crystals.
lparker
Post by lparker on Mar 30, 2015 7:31:01 GMT -5
I'm going to do 10's of pounds at a time. I'll just use the stainless to reheat the solution, so it will be in the pot for 15 minutes or so, and the pot gets rinsed when emptied.
Post by snowmom on Mar 31, 2015 6:21:42 GMT -5
would love to see before and after pictures!
lparker
Post by lparker on Mar 31, 2015 17:05:23 GMT -5
I AM not pleased with the crystals I got from Jim Coleman. Was supposed to be 30-40 lbs of dirty crystals per 1/2 bushel...after I power washed the 2 1/2 bushel I bought, I ended up with 35 lbs of what looks like quartz. I did let them know what I thought of them. Pictures will be coming of before and afters
Lee #1
lparker
Post by lparker on Apr 2, 2015 16:20:17 GMT -5
OK, the web site said 30-40 lbs of crystals and dirt. The picture on the web site showed a half bushel of dirty crystals. I set my expectations too high? I was so ticked off, I didn't take any "before" pics. They are soaking in the acid for the second time today. Maybe if the weather stays halfway decent, I'll be able to take some "after" pics tomorrow or the day after. I might have to start catering to the metaphysical crowd to get my money out of these.
Lee #1
lparker
Post by lparker on Apr 5, 2015 10:14:31 GMT -5
I know you are anxious to see that "after" pics so I said "the heck with the weather" and took a couple. The first pic is of the "mostly" clean crystals - the second of what I have left to clean. Enjoy! Sorry about that Had to do it. Lee #1
