Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Mar 29, 2015 22:27:03 GMT -5
Finished these up tonight for a pair of earrings. tricky stuff, but they turned out nice in the end.
meviva
Member since July 2013
Post by meviva on Mar 29, 2015 22:32:03 GMT -5
Very nice…I love the color.
Post by vegasjames on Mar 30, 2015 0:16:47 GMT -5
yes, fantastic color
Post by orrum on Mar 30, 2015 7:38:39 GMT -5
Man I use to not like Jade but that looks better n better.
Don
Post by Don on Mar 30, 2015 9:45:20 GMT -5
Man I use to not like Jade but that looks better n better. I used to be the same, but have recently converted to the religion of all things jade. I will say, this stuff in particular was not easy to cab at all. There was a matching pendant stone that I started with first and notice there's no pictures of it...that's because its in a pile of about 6 pieces. Found out the hard way that you cannot grind this stuff with 60-80 grit wheels. I had to start on 220 for these and go real slow. still had a lot of chipping issues, but the stones made it out in one piece, so I'm calling it a win. I also had to go back a few times and dry sand on the last 3 wheels of the pixie to bring up the shine. the material responds well to dry sanding and a little heat. This is jade from Washington that was introduced in another thread.
Post by roy on Mar 30, 2015 10:35:52 GMT -5
like the color on those !
adrian65
Member since February 2007
Post by adrian65 on Mar 30, 2015 12:03:54 GMT -5
Superb color and glossy shine on that jade!
Adrian
Post by orrum on Mar 30, 2015 12:42:00 GMT -5
My problem was with the outer face of the cab not polishing well Don. I am seeing so much nice Jade cabbing now that I may need to revisit Jade.
NDK
Post by NDK on Mar 30, 2015 18:17:11 GMT -5
Dang! I don't think I've ever seen a shine like that on jade. It's gorgeous!
Don
Post by Don on Mar 31, 2015 11:20:16 GMT -5
boy, I'm quickly losing my enthusiasm for this stuff after cutting a few more pieces. ugh. if you're in a solid "blue" area, it will shine fine so long as it survives cabbing, but if you've got black in it, good luck.
the green and white stuff I bought is even worse. crumbled like a cookie while slabbing and just fractured up while polishing. Wouldn't take a good polish no matter what. Making me long for the good Wyoming stuff again.
textiger
Member since May 2005
Post by textiger on Apr 2, 2015 12:26:10 GMT -5
Those are sweet. Nice work.
megalotis
Member since April 2009
Post by megalotis on Apr 2, 2015 15:45:11 GMT -5
Those are gorgeous! Too bad the material is so problematic! I still may try some of that stuff, but I'll steer clear of the lighter colors, and try to avoid material with black streaks. Thanks for the heads up!
Post by Fossilman on Apr 2, 2015 16:06:28 GMT -5
WOW!! Those are beautiful!!!!
Post by rockjunquie on Apr 4, 2015 11:46:04 GMT -5
Those are so BEAUTIFUL! I love the color and the shine is incredible.... hope I can get a shine like that!
Post by bobby1 on Apr 4, 2015 13:25:58 GMT -5
Vonson Blue? Bob
