Post by broseph82 on May 1, 2015 18:27:30 GMT -5
Post by Toad on May 1, 2015 21:04:49 GMT -5
Don't know about the wood, but that saw could come in handy...
Post by broseph82 on May 1, 2015 21:33:27 GMT -5
Don't know about the wood, but that saw could come in handy... I don't even have any pieces that big. Ha this pic came from the Mississippi petrified Forest page on FB.
Post by Fossilman on May 1, 2015 22:27:23 GMT -5
Hey that's my smaller saw...............LOL
Post by woodman on May 2, 2015 10:17:22 GMT -5
I would like to see that baby in action.
Post by Rockoonz on May 2, 2015 14:22:33 GMT -5
Wow, is that about a 5 foot blade? I think if I were to go that big it would be a drag saw, Maybe slower but I could make my own blades.
Post by woodman on May 3, 2015 9:24:46 GMT -5
Wow, is that about a 5 foot blade? I think if I were to go that big it would be a drag saw, Maybe slower but I could make my own blades. If you go to a drag saw make sure you use oil for lubrication, water don't work on hard materials.
Post by jamesp on May 3, 2015 11:15:09 GMT -5
That's a whopper
jerrys
Member since February 2014
Post by jerrys on May 4, 2015 13:46:02 GMT -5
Wow, is that about a 5 foot blade? I think if I were to go that big it would be a drag saw, Maybe slower but I could make my own blades. If you go to a drag saw make sure you use oil for lubrication, water don't work on hard materials. What kind of oil would you use? I'm finding that the mineral oil evaporates.
Post by Fossilman on May 4, 2015 22:19:47 GMT -5
I use mineral oil for my saws...........
Post by woodman on May 5, 2015 9:51:11 GMT -5
If you go to a drag saw make sure you use oil for lubrication, water don't work on hard materials. What kind of oil would you use? I'm finding that the mineral oil evaporates. off road diesel. cheaper.
Post by MrP on May 5, 2015 18:57:52 GMT -5
If you go to a drag saw make sure you use oil for lubrication, water don't work on hard materials. What kind of oil would you use? I'm finding that the mineral oil evaporates. Have used a number of different mineral oils and have never found that to be a problem. Is it straight mineral oil or mixed with something?......................MrP
Post by Rockoonz on May 5, 2015 21:44:58 GMT -5
I'm not familiar with the evaporation either. While diesel would have good properties as a cutting oil the smell it would leave on the rocks and the flammability are not things I would want to deal with. I got to see the aftermath of a fire in a shop that used diesel, makes it very understandable why it's the main ingredient in napalm. Drag saw at J2B2
Post by Peruano on May 6, 2015 7:47:59 GMT -5
Mineral oil evaporates. I reuse my stubs after rocks have been sawed off, after baking them in the sun for a month or so. Between the sun, heat, and bit of rain we have they are remarkably oil-free by the time I saw the end off and use again. Same result for the wooden chopping block on the end of my BBQ. I treat it with mineral oil and its good for a week or three, but soon is dry to the starting to open cracks stage even tho its tight hardwood. So evaporates, but not enough to worry about from an economical viewpoint. Tom
Post by woodman on May 6, 2015 9:51:38 GMT -5
Hows does water soluble oil work with saws that the blade is not running in oil? I seen one setup 45 years ago but do not remember any details of how well the saw cut using it.
jerrys
Post by jerrys on May 6, 2015 15:30:30 GMT -5
Diesel evaporates faster than mineral oil. I've seen a 48" saw that uses diesel. He looses 5 to 7 gallons if he cuts during the day in the summer so he only cuts at night. He has an argon fire suppression installed on the saw. The saw frame is a 20ft shipping container.
jerrys
Post by jerrys on May 6, 2015 15:40:13 GMT -5
What kind of oil would you use? I'm finding that the mineral oil evaporates. Have used a number of different mineral oils and have never found that to be a problem. Is it straight mineral oil or mixed with something?......................MrP I have tried Diala and Pella. I'm using them strait, no mixing. I find both will evaporate.
Post by Rockoonz on May 7, 2015 0:00:05 GMT -5
Water soluble machining oil is in no way suitable for rock saws, it's made for flushing cutting tools when machining metals. I use Lube cool 4800 in my 4 and 6 inch trim saws but wouldn't use it in a slab saw. Smokeys EZ cut in on the list of recommended cutting oils for Barranca, Think I might try it in the 2nd 14 inch HP after I rebuild it. barrancadiamond.com/pdf/tec/bd_slab_saw_coolants.pdf
Post by Rockoonz on May 7, 2015 0:03:37 GMT -5
The evaporation may be with naphathetic (smelly) based oils as opposed to paraffinic oils like food or medical grade oils.
