Post by jakesrocks on May 6, 2015 20:24:53 GMT -5
I have a chance to buy a 10" Lyman saw with power feed. Does anyone have any experience with Lyman saws ?
Post by Fossilman on May 6, 2015 20:32:12 GMT -5
I think Clyde had one-he liked it............
Post by jakesrocks on May 6, 2015 20:38:12 GMT -5
Thanks Mike. With the amount of slabbing I need to do, I need to add another 10" to the stable.
QuailRiver
Post by QuailRiver on May 6, 2015 20:45:03 GMT -5
Lyman Products owned Raytech Lapidary for many years until last year when they sold part of it off to Rick Scott of Scott Enterprises. Larry C.
Post by jakesrocks on May 6, 2015 20:49:09 GMT -5
Lyman Industries owned Raytech Lapidary for many years until last year when they sold part of it off to Rick Scott of Scott Enterprises. Larry C. Larry, do you happen to know if the hood for a 10" Lyman & a 10" Raytech are the same ? That's the only part missing from the saw I can buy.
QuailRiver
Post by QuailRiver on May 7, 2015 1:39:35 GMT -5
Lyman Industries owned Raytech Lapidary for many years until last year when they sold part of it off to Rick Scott of Scott Enterprises. Larry C. Larry, do you happen to know if the hood for a 10" Lyman & a 10" Raytech are the same ? That's the only part missing from the saw I can buy. Don, I don't know if they were the same or not but I just went out to the shop and measured my old Raytech 10" slab saw and the bed measures 20" x 13-1/2" and the Raytech plastic hood on mine measures 19-1/8" x 13" x 5-1/8". Hope this helps! Larry C.
Post by jakesrocks on May 7, 2015 9:36:11 GMT -5
Thanks for the measurements. I just sent the seller a message to let me know the table measurements on the Lyman.
Post by catmandewe on May 7, 2015 9:47:09 GMT -5
I think I have the hood brand new in a box somewhere.
Tony
Post by Fossilman on May 7, 2015 9:47:49 GMT -5
As knowing the skills that some machine shops have in ND,I bet SD has the same-have one custom made by the local shops around your area Don-if that's possible..
Post by jakesrocks on May 7, 2015 10:30:10 GMT -5
I think I have the hood brand new in a box somewhere. Tony Hey Tony, the seller just got back to me. Inside measurements of the Lyman table are 13 1/4" X 19 5/8". Sounds like the Lyman & Raytech hoods should be the same. The saw is supposed to be in very good condition. Even still has the lift out sump. Comes without the motor, but that's OK. I have a brand new 1/3 HP motor sitting on the shelf. If the hood you have will fit, how much do you want for it ?
Post by jakesrocks on May 7, 2015 11:01:53 GMT -5
As knowing the skills that some machine shops have in ND,I bet SD has the same-have one custom made by the local shops around your area Don-if that's possible.. Hey Mike, if I still had access to the equipment, I could vacuum form my own hoods. I did a lot of prototype vacuum forming for Fleetwood motor homes when I worked in their design shop. Anyway, I went ahead and ordered the saw. It should be here by the end of next week. Maybe the weather will settle down by then, and I can start slabbing the smaller pieces of picture jasper.
Post by catmandewe on May 7, 2015 22:50:32 GMT -5
I should be home tomorrow and I can check the size. I have no idea what it is worth, make me a reasonable offer.
Tony
Post by gingerkid on May 8, 2015 16:47:10 GMT -5
Post by Fossilman on May 8, 2015 21:32:00 GMT -5
GIT R DONE Don!!!!!!!!!!!!!! Thumbs up
Post by catmandewe on May 9, 2015 15:13:05 GMT -5
It is a Raytech hood for a 10" saw, 13 x 19 1/2, still in the box.
Post by orrum on May 9, 2015 15:21:29 GMT -5
U lucky dog Don! Tony hooked you up for resl!
Post by jakesrocks on May 10, 2015 10:15:43 GMT -5
U lucky dog Don! Tony hooked you up for resl! Yup, and at a price I couldn't refuse. Tony's the best.
Post by jakesrocks on May 12, 2015 13:57:41 GMT -5
WOO HOO, the Lyman saw just arrived. For a vintage saw it's in much better condition than I expected. It came with a brand new belt & motor pulley. Has a black blazer blade with very little wear. Just need to bolt my motor down, align the pulleys, add oil & start cutting.
As soon as the sun peeks out from behind the clouds I'll get pics to post.
Post by jakesrocks on May 12, 2015 14:36:24 GMT -5
Not the best pics but oh well. I love the power feed split nut system on these Lyman / Raytech saws. Right up top & easy to reach. Split nut & feed screw are both in excellent condition.
Post by captbob on May 12, 2015 15:32:08 GMT -5
SWEET!
