Post by stardiamond on May 15, 2015 16:22:43 GMT -5
Palm Owyhee Front Back Remainder glued to board. I bought a piece of Bruneau on ebay a while back and waited to use my slab saw to cut it. The Covington vise is like a wood vise and not very flexible. I glued the piece to the board and then rotated the board in the vise to align the cut. I ended up with a thick slab that I will split on my trim saw. The Covington uses a lot of material for the cut. I will end up with two slabs a little over 1/4 inch and should get another two slabs from the remaining piece. You never know how far the pattern continues. I'm pleased.
Roger
Post by Roger on May 16, 2015 10:09:08 GMT -5
Looking good! Love that Bruneau I will replace my blade in the next few months, not from wear, but to find a thinner blade. The Covington blade cuts beautifully - but it does eat material..
Post by Fossilman on May 16, 2015 12:55:14 GMT -5
Gotta love jasper's!!! Thumbs up
Post by Toad on May 16, 2015 14:52:14 GMT -5
Last two pics are awesome!
Post by stardiamond on May 25, 2015 15:01:54 GMT -5
I split the piece using my trim saw. I was afraid of gluing it and losing too much material on the slab saw. I hacked it up pretty bad but after cleaning up the slabs on the grinder I will still have more than 1/4" of even material for each slab. I expected the split to look like the back but it looks like the front. Buying blind, I scored. The slab on the left is the other side of the front and the second piece is the other side of the back of the unsplit slab.
Post by Fossilman on May 25, 2015 18:27:03 GMT -5
Yes-SCORE!!!!!!
