Post by vegasjames on May 21, 2015 22:59:36 GMT -5
Went out digging for 10 hours and ended up with 600 pounds of chrysocolla: Some of my favorite pieces:
Post by orrum on May 22, 2015 6:18:57 GMT -5
Thst a lot of purty rocks!
Post by snowmom on May 22, 2015 8:54:35 GMT -5
wow, well worth the effort and the aspirin you probably had to take afterwards. Those are beautiful! You must have hit the mother lode!
Post by broseph82 on May 22, 2015 12:53:12 GMT -5
Went out digging for 10 hours and ended up with 600 pounds of chrysocolla: Some of my favorite pieces: vegasjames I luv u. I'll be looking in the buy/sell/swap area shortly ;-)
Post by vegasjames on May 22, 2015 15:16:56 GMT -5
wow, well worth the effort and the aspirin you probably had to take afterwards. Those are beautiful! You must have hit the mother lode! I was sore, but I don't take aspirin for anything. In fact I don't take any pharmaceuticals whatsoever. Last time I did was an ibuprofen when I had a 107F fever from the measles 25 years ago or so. I only took it because my girlfreind was hounding me to take one for the fever. Did not do much good. Only dropped the fever a few degrees. That was a good day digging there since normally I only get about 300-400 pounds a day there. It was getting a lot harder to find as I went on. I like this stuff also since some of it contains the silver ore bromargyrite, which is bright green: Here are some things I made from the material:
Post by snowmom on May 22, 2015 18:09:18 GMT -5
absolutely gorgeous!
Post by Fossilman on May 22, 2015 19:59:39 GMT -5
SCORE!!!!!!!!!!!!!!!!!!!
Post by quartz on May 22, 2015 22:29:42 GMT -5
60lb./hr. that's good pickins. Like your projects too, well done.
Post by vegasjames on May 23, 2015 3:31:31 GMT -5
60lb./hr. that's good pickins. Like your projects too, well done. Thanks. My other favorite spot to dig is fairly close and I get gem silica there. I will try to get some pics up of that as well when I get the cabs I am working on finished.
Post by jamesp on May 23, 2015 13:23:28 GMT -5
Was your backhoe a gas burner or a diesel. ?
Post by vegasjames on May 23, 2015 15:19:50 GMT -5
Was your backhoe a gas burner or a diesel. ? Neither. Muscle and determination powered. That was my best day though. Normally I only get around 300 pounds per day of digging. So when I weighed out the total I was pretty ecstatic.
Post by jamesp on May 23, 2015 20:37:47 GMT -5
Was your backhoe a gas burner or a diesel. ? Neither. Muscle and determination powered. That was my best day though. Normally I only get around 300 pounds per day of digging. So when I weighed out the total I was pretty ecstatic. Never seen so much ore. Concerns about drilling for metal free water in your territory. We shave radon in our granite. so some wells radioactive. They have discovered the granite aggregate in cement is radioactive from certain quarries. Now they are finding high levels of radiation in high rise buildings. Buildings never tested for years because there was no thought about concrete being radioactive. Just basements sitting on granite. i do not know if they are being overly sensitive. Various opinions about the danger of radon. Fine material James. I would think that it is money in the bank.
Post by vegasjames on May 23, 2015 21:09:28 GMT -5
Neither. Muscle and determination powered. That was my best day though. Normally I only get around 300 pounds per day of digging. So when I weighed out the total I was pretty ecstatic. Never seen so much ore. Concerns about drilling for metal free water in your territory. We shave radon in our granite. so some wells radioactive. They have discovered the granite aggregate in cement is radioactive from certain quarries. Now they are finding high levels of radiation in high rise buildings. Buildings never tested for years because there was no thought about concrete being radioactive. Just basements sitting on granite. i do not know if they are being overly sensitive. Various opinions about the danger of radon. Fine material James. I would think that it is money in the bank. I have not seen any evidence of radon problems here is Las Vegas, but we have plenty of other things to worry about. Asbestos is the soil, perchlorate and uranium in the water, etc. Radon is a problem in surrounding areas and further North, such as around Fallon. I have weighed out some 10 pound lots of some nicely colored material. I will try to get it photographed and posted as soon as I can. Was too cloudy today.
