Post by snowmom on May 30, 2015 8:41:23 GMT -5
shakes head. I can't even begin... wth?
Post by Fossilman on May 30, 2015 9:53:47 GMT -5
HUMMMMMMMMMMM,one word-CUT!
Post by Deleted on May 30, 2015 10:28:42 GMT -5
Its just granite. Soak it in iron out or pool acid to remove Huron varnish to see true colors.
Post by captbob on May 30, 2015 11:23:45 GMT -5
Alien egg.
Post by snowmom on May 30, 2015 11:50:30 GMT -5
Post by victor1941 on May 30, 2015 12:48:21 GMT -5
It looks like a piece of wood that got fractured and resealed.
Post by snowmom on May 31, 2015 4:21:55 GMT -5
not so sure about the granite. as it happens, it has been soaking in iron out for a while. boy was it stained. Still is, but I can see the underlying colors are light to dark green (like the blue green of some basalt)and micro fine grained, and the seams are either clear or white quartz stuff. looks like a brecciated layered argillite with the silt layers being light and dark green. Then that seems to have been infilled with thick clear silica which picked up the staining. .
Post by jamesp on May 31, 2015 6:31:04 GMT -5
You have the most complicated geology snowmom. The rocks you post keep me amused because they are unexplainable LOL. Gotta look at them, they are always unexplainable(I should add) from my limited geo background. None the less beautiful. Hard to say if they are even from this planet or recreated by forces of meteor impact. Which is amusing too. Keep em coming.
