FLrockhound
Member since July 2014
Post by FLrockhound on Jun 4, 2015 23:34:20 GMT -5
Well, I just ordered a second Lortone 45C from The Rockshed, since I really love the one I have that's 40 years old. To me its an excellent tumbler. I also purchased a LOT-O 4lb capacity (i had two vibes in my shopping cart an i didnt realize i had removed the UV) which is perfect for the amount of rocks I process. It will only be used for the polishing stage until I get an extra bowl. I'm pretty excited I was able to order some new equipment an a lb of tin oxide this evening to expand my addiction.
Post by captbob on Jun 5, 2015 0:29:58 GMT -5
Awesome! Nice additions to your shop for sure.
Gotta ask... why tin oxide? It's like 5 times more expensive than AO isn't it? I've read tin oxide excels when used with softer stones, and I had fantastic results using it on obsidian, but I thought you did mostly agates, jaspers and the like.
Can you put the bigger 10 pound bowl on your new vibe if you choose to?
FLrockhound
Post by FLrockhound on Jun 5, 2015 12:10:33 GMT -5
Awesome! Nice additions to your shop for sure. Gotta ask... why tin oxide? It's like 5 times more expensive than AO isn't it? I've read tin oxide excels when used with softer stones, and I had fantastic results using it on obsidian, but I thought you did mostly agates, jaspers and the like. Can you put the bigger 10 pound bowl on your new vibe if you choose to? I just wanted to stock up on different polishes an grits that I could have on hand if needed so I can start experimenting with rocks I've never tried to tumble. I'm not sure yet about putting the 10lb bowl on it. That's a good question, I'll have to look into it. That would be nice if I wanted polish a larger load.
