meviva
Member since July 2013
Post by meviva on Aug 19, 2015 19:30:10 GMT -5
I have a Lortone QT-66. I have one barrel going right now and it weighs about 9 lbs. full. I want put the other one on and am wondering if 18-20 lbs. total is too much for the motor to handle. Somewhere I read that the total weight of the barrels full should be 6 lbs. each. Keeping the weight at 6 lbs. including the barrel doesn't fill the barrel up enough. Is it too hard on the motor or could it catch fire?….that motor gets hot! I haven't been tumbling too much lately and I want to get back into it.
Thanks, Andrea
Post by Drummond Island Rocks on Aug 19, 2015 20:08:53 GMT -5
I have been running my lortone QT12's for years non stop and have never one time weighed a barrel. I have never burned up a motor and the only time they need a shove is if the power goes out with a full barrel on it.
rocks to 3/4 full plus water plus one pound of grit so I am sure they weigh a lot more then 12 pounds.
meviva
Post by meviva on Aug 19, 2015 20:24:42 GMT -5
Thanks Chuck…I was hoping that would be the answer.
Post by Deleted on Aug 19, 2015 20:59:18 GMT -5
Greetings [meviva] Andrea I have had 18.6kg (41lb) running on my Lortone QT 12/66 and it still runs without issue, my motor runs at 75ºC (167ºF). Please check out my Sticky's below. -- Please click images to open larger images in a new Tab, same with everything that is Underlined! I currently have a 3lb Beach (UK), Lortone QT 12/66 (USA) rotaries & 2x Viking Vibrasonic (Diamond Pacific) (USA) virbrating tumblers, with Silicon Carbide grit F80, F220, F600, F1200, with Tin Oxide (1.0 micron) & Aluminum Oxide (1.0 micron & 0.3 micron) polishes. I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens (15mb) sometimes come for a visit & about 4 miles west from that monstrosity & 7 miles west of this new monstrosity! Sticky's: their contents are resource information 1#: Vendors worldwide (2mb), 2#: How to use the forum, 3#: How to identify rocks & minerals, 4#: Save money on expensive grits & polishes, 5#: Aussie Lapidary Forum: Rock Tumbling Guide!
meviva
Post by meviva on Aug 19, 2015 21:11:33 GMT -5
Thanks Andrew….that makes me feel better. I always worry about it when I keep it running and I leave the house.
