elemental
Member since September 2015
Post by elemental on Sept 6, 2015 20:54:25 GMT -5
I was reading through a few older threads on tumbling labradorite. I have a vibratory tumbler and some shaped pieces of stone. I saw a lot of replies that were saying don't tumble labradorite, but I wondered if anyone had any luck with final smoothing and polishing in a vibratory tumbler? Would save me a ton of time if there is a knack to it people could share.
Anyone know?
Wanted to add, I had taken the pieces to a 600 diamond polish already.
Post by orrum on Sept 7, 2015 13:45:45 GMT -5
I want to know also!
elemental
Post by elemental on Sept 7, 2015 15:11:41 GMT -5
I cut a lot of cabs. Looking for short cuts
stonemaster499
Member since July 2014
Post by stonemaster499 on Sept 7, 2015 15:40:05 GMT -5
it can be easily done with excellent results in Vibe. You must slow down the vibe with thickening agents (eg sugar), and /or run it slower so no banging occurs. 50% media. Dry polish technique, or you will have less than acceptable results. Trick is the opposite of hard stones, meaning the longer in each stage, THE WORSE it gets.... so move it on sap! good luck.
verhexen
Member since June 2015
Post by verhexen on Sept 7, 2015 18:19:55 GMT -5
Definitely dry polish. If you use 1000 grit, it should be for no longer than 24 hours. I have some pictures of my tumble I need to post.. I did not use dry polish and was slightly disappointed, but I got quite a few good pieces out of the batch.
elemental
Post by elemental on Sept 7, 2015 19:29:37 GMT -5
ok, thanks! When I do it, I will show some pics of what I ended up with. It will probably be a few weeks, because I don't have many of the labradorites ready yet.
