rykk
Member since September 2011
Post by rykk on Sept 14, 2015 13:58:15 GMT -5
Hi, all - been a while since I was here. I modified a 20" Lortone jiggle pan (vibratory lap) to have a quasi-reciprocal motion rather than the random-ish motion of the original, eccentric load design. Does a good job eliminating up/down hopping of the rocks and no more "orange peel" surfaces on rocks like obsidian.
I got an offset shaft that a member here - "cpdad" I think - made for me that was great. It has - if memory serves - a 2 or 3mm offset. The new design grinds and polishes much better than the old one. One "problem" is that it takes a bit longer and can have trouble getting the rocks moving when they are polishing on a new felt pad. I want try a larger offset and hope I can get one made. I had, initially, been scared away from a big offset after seeing a U-tube video demonstrating the Reciprolap. Just seemed too violent and I felt it could slam the rocks/slabs against each other too hard. I want to try a somewhat larger offset and see if it speeds things up. If anyone can help, let me know. Thanks! Rick
rykk
Post by rykk on Nov 4, 2015 7:46:29 GMT -5
Bump...
Post by Rockoonz on Nov 4, 2015 23:31:49 GMT -5
It was probably cpdad he made some shafts for folks awhile back. Did you try a PM?
