Post by jamesp on Sept 20, 2015 19:24:05 GMT -5
Rolled 15 pounds of coral and pet wood in the rotary for 14 days for final coarse grind with SiC 80 and clay. Did about seven 80 grit runs for a week each before the 14 day run. Figured it is beat down the SiC 80 to less than 500 after 2 weeks. So into the vibe for the standard 3 days with AO 500 and 1.5 cups sugar. And, just started these NOT silicified fossilized oysters with a 1/3 dose of SiC 80 and clay in the rotary. They will have to be done in 220 as they are probably too soft to break down SiC 80. They will be run in the vibe using Jugglerguy's master corn husk dry formula, starting with AO 500 in the vibe. Will add some abalone shell with them as soon as Post Office delivers them. Fingers crossed. Having great luck coarse tumbling large delicate plates of botryoids with SiC 80 and thick clay slurry. Hardly any breakage.
Post by Jugglerguy on Sept 20, 2015 19:34:13 GMT -5
Good luck with those, James!
Post by orrum on Sept 21, 2015 6:46:10 GMT -5
Can't wit for the abalone shell James!
Post by Noosh9057 on Sept 21, 2015 7:43:15 GMT -5
Good luck can't wait to see the final product.
Roger
Post by jamesp on Sept 21, 2015 8:14:59 GMT -5
Can't wit for the abalone shell James! If memory serves well abalone is thick shell Bill ?
Post by orrum on Sept 21, 2015 9:21:03 GMT -5
Yes and b careful of the dust it's toxic I think.
Post by jamesp on Sept 22, 2015 11:52:47 GMT -5
About half way into AO 500 (36 hours) in the vibe and would say finish is right on course. Usually takes 3 days after being in 220 in the rotary. Running low on SiC 220 so I let the last SiC 80 run 14 days. Clay added from beginning of 14 days to make only a chocolate milk consistency. Ran the 14 day 80 slurry thru a sheet and could not find any black particles-close inspection. Pretty sure the 220 step will get skipped in the future. Appears the clay is scavenging every particle of grit. Results after 2.5 days in sugar and AO 500. Will 'clean' sugar off with Borax and AO 14,000 for 24 hours. PS. Ran vibe a while back in AO 500 with sugar in hot greenhouse for 5 days and never had to add water. Opened it up day 3 and day 5. No adjustments on slurry. Two step tumble:
Post by jamesp on Sept 23, 2015 15:08:04 GMT -5
Whole oyster only after a day in SiC 80. Soft material.
Post by Deleted on Sept 23, 2015 15:20:04 GMT -5
Greetings [jamesp] James what happened to your vibe that you have not been using it of late?! Please check out my Sticky's below. -- Please click images to open larger images in a new Tab, same with everything that is Underlined! I currently have a 3lb Beach (UK), Lortone QT 12/66 (USA) rotaries & 2x Viking Vibrasonic (Diamond Pacific) (USA) virbrating tumblers, with Silicon Carbide grit F80, F220, F600, F1200, with Tin Oxide (1.0 micron) & Aluminum Oxide (1.0 micron & 0.3 micron) polishes. I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens (15mb) sometimes come for a visit & about 4 miles west from that monstrosity & 7 miles west of this new monstrosity! Sticky's: their contents are resource information 1#: Vendors worldwide (2mb), 2#: How to use the forum, 3#: How to identify rocks & minerals, 4#: Save money on expensive grits & polishes, 5#: Aussie Lapidary Forum: Rock Tumbling Guide!
Post by jamesp on Sept 23, 2015 18:44:46 GMT -5
Greetings [jamesp] James what happened to your vibe that you have not been using it of late?! Please check out my Sticky's below. -- Please click images to open larger images in a new Tab, same with everything that is Underlined! I currently have a 3lb Beach (UK), Lortone QT 12/66 (USA) rotaries & 2x Viking Vibrasonic (Diamond Pacific) (USA) virbrating tumblers, with Silicon Carbide grit F80, F220, F600, F1200, with Tin Oxide (1.0 micron) & Aluminum Oxide (1.0 micron & 0.3 micron) polishes. I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens (15mb) sometimes come for a visit & about 4 miles west from that monstrosity & 7 miles west of this new monstrosity! Sticky's: their contents are resource information 1#: Vendors worldwide (2mb), 2#: How to use the forum, 3#: How to identify rocks & minerals, 4#: Save money on expensive grits & polishes, 5#: Aussie Lapidary Forum: Rock Tumbling Guide! All is well Andrew. Finished a couple of batches w/help of vibe and finished a couple all the way with the rotary. Now vibe is backed up with several batches from rotaries. So it should be running full time for 10 days or so. It gobbles up the rotary output w/out effort. You know the game. Plus going to try some dry batches.
