cowboy32141
Member since November 2015
Post by cowboy32141 on Nov 2, 2015 12:04:12 GMT -5
I've been looking for days with no luck.... where can I find stone slabs that are 1" thick? I want to make home made ear plugs but I need them to be at least 12 mm thick and the thickest I can find is 5.75mm thanks!
Post by captbob on Nov 2, 2015 12:12:18 GMT -5
All ya gotta do is ask! Many here would be delighted to sell you thick slabs.
What type material (rocks) are you looking for?
And, welcome to the forum!
ETA: 32141 as in over by Daytona?
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Nov 2, 2015 12:43:30 GMT -5
Slabs are not typically cut 1" thick. You'll need someone to cut them for you as a special order. Do you have material for slabbing?
Post by captbob on Nov 2, 2015 12:56:34 GMT -5
Don, you are thinking like a cab maker and not like a rock tumbler I cut far more 1 inch, or thicker, slabs to break up for tumbler fodder than I cut thin slabs as used to cab. Cutting thick slabs is also much easier, as there is no need to be precise.
