Post by jakesrocks on Nov 10, 2015 16:13:19 GMT -5
Made a very nice equipment score. Everything arrived yesterday, and I'm still unpacking. How often do you see a 40 year old unrestored machine that's this clean ? Just need to steam clean the inside of the pan & hood. And then there's the Crown bead mill. Missing the motor & drive wheel, but otherwise complete. And a Rock Rascal Model T. Needs a motor & good cleaning, but the bearings are smooth & the blade has lots of life left. Even came with the vise & a spare blade. More pics coming as I get things unpacked & sorted out.
Post by captbob on Nov 10, 2015 16:21:19 GMT -5
Looking good! Don is doing the happy dance! Bet that Ed, Intheswamp, would take that Rock Rascal off your hands if you're not keeping it.
Post by jakesrocks on Nov 10, 2015 17:07:57 GMT -5
Gonna clean it up & think about it for a few days Bob.
Intheswamp
Member since September 2015
Post by Intheswamp on Nov 10, 2015 18:28:56 GMT -5
<Imagine the smiley eating popcorn emoticon here>
Post by rockpickerforever on Nov 10, 2015 18:41:04 GMT -5
Post by broseph82 on Nov 10, 2015 20:42:04 GMT -5
jakesrocks That crown lap machine is awesome. I scored the same one off eBay with the original dayton motor. I love how spacious the crown lap machines are around the wheels. I wouldn't mind finding another 4 wheel Crown lap machine
unclesoska
Member since February 2011
Post by unclesoska on Nov 10, 2015 21:50:59 GMT -5
i have a unit identical to this except it's not near as nice as the one you got- mine has a rusty bottom. really nice score for you!
Post by orrum on Nov 10, 2015 21:54:34 GMT -5
Bunch of nice equipment Don!
Post by Rockoonz on Nov 10, 2015 21:56:02 GMT -5
My two main grinding & sanding units are a Crown unit just like it and a Lortone Max Pro 8, which is about the same.
bsky4463
Member since September 2013
Post by bsky4463 on Nov 10, 2015 22:36:00 GMT -5
Upside down poly mounted in a cool shroud w motor mount in top...I like. I have 2 polys sitn could fab something similar....Cheers
Post by jakesrocks on Nov 10, 2015 23:31:44 GMT -5
I'll tell you what. With the motor & arbor mounted, that thing is heavy.
It wouldn't be hard to bend up a housing like that. Really only 2 pieces of metal. The pan & back are one piece, and the sides, top & front top lip is the other. The pan / back is welded solid to the sides & top. All 16 gage steel.
Post by jakesrocks on Nov 11, 2015 11:21:20 GMT -5
More of the haul. Loretone 8" pan & hood. Bead drilling vise. Several pics to show details. First pic shows vise mounted in tank on 2 brass pins. The vise assembled. Vise disassembled. 2 pics to show large & small countersunk center holes to take different sized beads.
Post by captbob on Nov 11, 2015 11:27:05 GMT -5
Your orchard needs watering
Post by jakesrocks on Nov 11, 2015 11:35:18 GMT -5
LOL, Bob, that's the result of 4 years in a row of spring flooding. Had to have 50 trees removed.
Post by jakesrocks on Nov 15, 2015 14:00:56 GMT -5
WOO HOO ! Just pulled the bead mill apart. There is zero wear in the pan or on the wear plate. The machine has never been used. Both aluminum parts are still shiney fron the original machining. How's that for a machine that was produced in the early 70's ? There's a small amount of tarnish on the bowl. Nothing that a little 0000 steel wool won't polish out.
Post by jakesrocks on Nov 16, 2015 19:12:49 GMT -5
Unpacked a few more things today. There were 8 of these 8" end plates. each with the rubber cushion and polishing pad. And each marked on the back for a different grit of diamond paste.
Post by jakesrocks on Nov 16, 2015 19:15:02 GMT -5
A pack of 5 - new 8" rubber pads. And a Crystalite 8" Starlap which has barely been used.
Post by Fossilman on Nov 16, 2015 21:10:50 GMT -5
That Poly is crazy cool,so is the Rascal..................
Intheswamp
Post by Intheswamp on Nov 16, 2015 21:18:32 GMT -5
Yeah, that Rock Rascal...nice.
Post by jakesrocks on Nov 16, 2015 22:06:15 GMT -5
I already have a 6" Rock Rascal saw. I'm gonna clean this one up, and may decide to sell it.
