Post by Fossilman on Nov 10, 2015 20:03:27 GMT -5
I just got my Poly put back together,since I bought it-got rid of the bump wheels and replaced it with expando wheels.... Question,I'm teaching myself to run the machine... The left wheel holds the sandpaper on the wheel pretty good,but the right side,kicks it off,left and or right....All the paper is 8 inch,as are the wheels..........As soon as the stone touches the paper-boom-its heads off the wheel!!!!!!!!! Am I doing something wrong or what!!!!!!!!!!!!
Post by orrum on Nov 10, 2015 21:57:28 GMT -5
Is it turning the correct direction?
Post by Rockoonz on Nov 10, 2015 21:59:49 GMT -5
That would be my first guess. If the expando is on backwards it won't expand. If it's a lortone there's an arrow, but hard to see because it's small.
Post by Rockoonz on Nov 10, 2015 22:01:32 GMT -5
Also it needs to be spinning at 1700 rpm +/- to expand. if spinning too slow it might slip too.
Post by Fossilman on Nov 10, 2015 22:43:05 GMT -5
Ok,all great answers,will double check tomorrow......Thanks all............
Post by Fossilman on Nov 10, 2015 22:45:02 GMT -5
I'm thinking,it might be on wrong,will switch it to other direction...
Post by jakesrocks on Nov 10, 2015 23:51:06 GMT -5
Maybe Poly wants a cracker Mike. ROGLMAO
Post by Fossilman on Nov 11, 2015 10:20:08 GMT -5
Maybe Poly wants a cracker Mike. ROGLMAO Ok Brother,who put a quarter in you!!!!! ROTFLMAO......... I'm sure I put the wheel on back asswords!!! "Rolling eyes"..LOL
Post by jakesrocks on Nov 11, 2015 10:37:32 GMT -5
LOL. It happens Mike. Been there, done that.
Post by captbob on Nov 11, 2015 10:45:28 GMT -5
Been watching this all along, but the answer was covered quickly.
One other possibility (for future knowledge) is when a drum gets old it can lose it's expandability (is that a word?) - anyway, they can basically wear out. You can buy an old used drum and it may not expand anymore. Really old ones look like dry rotted tires, buy they quit expanding well before that point.
Post by Fossilman on Nov 11, 2015 13:25:32 GMT -5
I know they are pretty good shape-dealt with Roy on this equipment..Top notch guy..Thumbs up.. The time I did put on the polisher was showing amazing results with some double sheen Obsidian.... I think I'm going to like it a lot!! LOL
Post by Fossilman on Nov 11, 2015 13:26:38 GMT -5
That's why I like this forum,always great advice and some ribbing to go with it-True brothers and sisters,,,LOL Two thumbs up
Post by orrum on Nov 11, 2015 14:48:30 GMT -5
Glad u got er fixed pardner!
Post by Fossilman on Nov 11, 2015 18:41:40 GMT -5
Found the problem,it was the sandpaper I bought,sub standard crap-never do that again!!!!!!!!! Just did all my free forms on my cabbing machine and the presanding too........... Might as well get rid of the Poly and invest in a vibrating flat lap......Makes better sense than having two of the same...When the cabbing machine can do the same and more than the Poly....
Post by Peruano on Nov 11, 2015 18:52:55 GMT -5
Just to round out the total array of factors that will cause a belt to creep laterally, I'd always check to see if your machine is level (especially if the belt tends to creep one way only). Leveling the machine can prevent that, but a good belt should not move off the wheel unless radically off the level. Always try a new belt to see if it does the same thing. Keep on grinding. Tom
Post by Fossilman on Nov 12, 2015 10:45:37 GMT -5
Just to round out the total array of factors that will cause a belt to creep laterally, I'd always check to see if your machine is level (especially if the belt tends to creep one way only). Leveling the machine can prevent that, but a good belt should not move off the wheel unless radically off the level. Always try a new belt to see if it does the same thing. Keep on grinding. Tom Yes,tried different belts-most stayed on,but some did the dance.....Will check to see how level it is on the stand-But in all seriousness,it's still going down the road....Why have to pieces of equipment that do the same work,plus my cabbing machine does a bit more...LOL I know the "Poly" is in great shape,I tore it apart and looked it all over and changed the rounds out too...Rebuilt the stand,painted and put back together...
Post by mohs on Nov 13, 2015 16:14:51 GMT -5
yep I just started up my expando and many of my old belts did the dance I'm thinking there warped from the summer heat hopefully
Post by johnjsgems on Nov 18, 2015 13:02:55 GMT -5
I stopped selling Raytech drums because of inconsistent diameters. Sometimes off by 1/4". You can look from the side and see which direction they need to turn to expand. The wrong way the "fingers" will lay down. The correct way centrifugal force throws them outwards. I had a really experienced customer that bought new drums from me to replace some 20 year old drums. He called to tell me for 20 years he cursed the "stupid drums" for not holding the belts tight. When he saw the arrows on the new drums he realized he ran the old drums backwards all those years.
Post by jakesrocks on Nov 18, 2015 14:36:36 GMT -5
Hey John, who's making the best expando's these days ?
Post by Rockoonz on Nov 19, 2015 0:16:40 GMT -5
The Lortone (Scott Murray) expandos are the best, made in the USA. I have done repair and maintenance work on the molds. I have worked with the people in Oregon who compound the rubber used to make them.
