Post by woodman on Nov 17, 2015 22:11:46 GMT -5
I am playing with making a cab out of part of this slab and was thinking about something in the shape that I have drawn, or something to that effect. The slab is 2 1/2 inches wide or from top to bottom, not left to right I have made cabs in the past but never free forms. Any suggestions?
Post by Pat on Nov 17, 2015 22:18:57 GMT -5
That's a very pretty slab. You can probably get more cabs out of it.
I prefer free forms and circles to other shapes. I don't have any suggestions.
micellular
Rock fever is curable with more rocks.
Member since September 2015
Post by micellular on Nov 17, 2015 22:23:41 GMT -5
Freeforms might be addictive...
I really like the shape you've drawn out, actually. I like how the points in the fortification barely intersect the edge - that gives the pattern a sense of coherence and unity despite the irregular shape.
Another idea could be incorporating the two tubes to the left. You might be able to make a face! The white blob to the further left almost looks like a hat.
Post by woodman on Nov 17, 2015 22:24:33 GMT -5
That's a very pretty slab. You can probably get more cabs out of it. I prefer free forms and circles to other shapes. I don't have any suggestions. agree, there are more in there, I may have to get the boss involved before I do any cutting and see what she has to say.
Post by woodman on Nov 17, 2015 22:26:52 GMT -5
Freeforms might be addictive... I really like the shape you've drawn out, actually. I like how the points in the fortification barely intersect the edge - that gives the pattern a sense of coherence and unity despite the irregular shape. Another idea could be incorporating the two tubes to the left. You might be able to make a face! The white blob to the further left almost looks like a hat. I see what you mean about the face, never looked at it from that angle. I was thinking the tubes could be another cab. Indecision is the key to flexibility.
micellular
Post by micellular on Nov 18, 2015 9:55:18 GMT -5
Here's a two-cab idea with a face. Arrows indicate which direction could be up.
Post by Pat on Nov 18, 2015 10:05:23 GMT -5
woodman and micellular how did you draw those colored circles onto the photo? Thanks.
micellular
Post by micellular on Nov 18, 2015 10:21:10 GMT -5
Post by woodman on Nov 18, 2015 10:34:27 GMT -5
Here's a two-cab idea with a face. Arrows indicate which direction could be up. Thanks for the ideas. Yes paint works good, I used another photo editing program i have, photosuite.
Post by Fossilman on Nov 18, 2015 10:38:43 GMT -5
Just starting out of the gate,making cabs and mine are all free form.....I just go by what my eyes tell me to do..... Looks like you will have a great project going there on this piece!!!
Post by kk on Nov 18, 2015 10:49:44 GMT -5
Dont be afraid using the open tubes. They can be a wonderful addition to any master-cab. As with any cab, ensue some form of balance pleasing to you.
Post by cobbledstones on Nov 18, 2015 11:07:40 GMT -5
there is an alien in that slab
Post by woodman on Nov 18, 2015 13:16:55 GMT -5
Dont be afraid using the open tubes. They can be a wonderful addition to any master-cab. As with any cab, ensue some form of balance pleasing to you. Actually, the tubes are not open at all. They do look like it in the photo, but they are filled with agate. thanks for the comment.
Post by woodman on Nov 18, 2015 13:17:44 GMT -5
there is an alien in that slab That juste might work!
Post by stardiamond on Nov 18, 2015 14:04:18 GMT -5
You identified the best scene in the slab and should use it even if it is the only preform you get. The problem I see with the framing is that the cab might have a clunky shape. I've cut a lot of those. I cut free forms and also use templates. I have quite a few and lay them over the slab to design. I would use a large pear shape with orientation the same as yours and center the scene.
Post by rockpickerforever on Nov 18, 2015 14:08:22 GMT -5
What Mike said, your eyes will pick out the best scene and shape. I prefer free form to calibrated cabs any day! That way you can maximize the final cab size, by not having to fit a constrained shape/size.
I do love the alien! Might say I have a soft spot for them.
Post by Bluesky78987 on Nov 18, 2015 15:20:50 GMT -5
My only advice would be to turn the slab over and really pay attention to how the pattern tapers off (or not) between the two sides. Sometimes when you start grinding down through it the pattern really changes. You might need to offset your original outline a little to account for this.
Post by cobbledstones on Nov 18, 2015 16:26:35 GMT -5
I do love the alien! Might say I have a soft spot for them. me too
Post by rockpickerforever on Nov 18, 2015 18:40:30 GMT -5
I do love the alien! Might say I have a soft spot for them. me too And I think that soft spot is located between my ears, lol.
