joejansal
Member since August 2009
Post by joejansal on Nov 30, 2015 18:41:52 GMT -5
hi all, I wet band saw my pieces, having lots of trouble seeing lines have tried all types of pens and etc. what is best to draw patterns on dark rocks. the black permanent marker works best but when wet cannot see the lines. do they make a white perm marker, have tried the white paint markers but they plug up very quick. any help would be appreciated thank you joe sal
cwdiver
Work is just Surface Interval
Member since October 2015
Post by cwdiver on Nov 30, 2015 19:35:36 GMT -5
Joejansal I have used a sharpened soapstone pencil line with my trim saw . This might wash off ? with water flowing over your piece. Give it a try...................Gary
Post by mohs on Nov 30, 2015 19:41:34 GMT -5
good question ! Hope solution can be found better than blowing the water off the rock Ed
Post by Deleted on Nov 30, 2015 20:08:00 GMT -5
I use an aluminum scribe when marking on dark stones. Dave
Post by vegasjames on Nov 30, 2015 20:26:48 GMT -5
I use an aluminum scribe when marking on dark stones. Dave Yes, I use aluminum wire.
Post by Jugglerguy on Nov 30, 2015 21:07:15 GMT -5
I haven't used this, but it's what a friend of mine uses all the time to mark stones. It's a DecoColor Extra Fine opaque paint marker. She uses a yellow one.
Post by victor1941 on Nov 30, 2015 22:36:46 GMT -5
I have used a silver marking pen with a tip that marks about one sixteenth inch on dark stone with good results. My slabs are trimmed using a mineral oil and the marks are easily visible until the oil gets mucked up.
Post by pauls on Dec 2, 2015 21:52:08 GMT -5
Keep a lookout when you are driving around for electricity linesmen, overhead electricity cables are Aluminium, ask nicely and I'm sure they will have a cable offcut they could spare, peel it down to individual wires and sharpen one to a point, instant stone marking pencil, much better than pencils or sharpies and will not wash off. Another source is metal shops that do TIG welding, they always have plenty of the end bits of TIG wire. Aluminium will not mark on polished stones though, it relies on lodging bits of metal in the rough surface. Another option is bronze brazing wire
Post by Rockoonz on Dec 2, 2015 22:30:45 GMT -5
I have TIG scraps and brazing wire ends, mostly use the aluminum but sometimes the yellow brass shows up better.
Post by parfive on Dec 3, 2015 1:18:17 GMT -5
If the wife don’t work in a bucket truck or a welding shop, just ask her for a knitting needle.
