Post by Fossilman on Dec 8, 2015 10:50:02 GMT -5
There ya' go..............
Post by captbob on Dec 8, 2015 14:29:04 GMT -5
The pan sets on a pin as the larger pulley turns the bolt with the bead on it the bead bumps the bottom of the pan Walt uh... what? Here I was thinking that the purpose of "the bolt with the bead on it" was to create an off balanced rotation of the larger pulley thus creating the vibration. Are you saying that the vibration is caused by the "bead" bumping the pan? Not sure I'm buying that...
Post by jamesp on Dec 8, 2015 14:42:22 GMT -5
Great counter balance and coming off the pulley shaft to isolate the motor manofglass
Post by manofglass on Dec 8, 2015 14:49:17 GMT -5
captbob your right the bead don't hit the pan I just stuck it in for fun I traded a glass grinder for this thing
walt
Post by Starguy on Dec 10, 2015 21:15:42 GMT -5
Very cool. Have you polished anything with it yet?
Post by manofglass on Dec 10, 2015 22:03:27 GMT -5
I wont do anything with rocks tell after I rebuild the tools sometime next year it gets to set tell then
Walt
