Post by glennz01 on Dec 18, 2015 13:03:00 GMT -5
Well, due to recent events, I haden't had time to turn off my rock tumbler or clean it out for 3 weeks. I only had initial 80 grit in for course grind with slurry from my last batch. This will be an interesting cleanout
Post by Rockoonz on Dec 18, 2015 14:40:50 GMT -5
We often do coarse for a month, changing it after the first week then letting the 2nd batch break down and become medium/fine grit. After that we go straight to prepolish on all but the hardest rock.
rastageezer
Member since December 2013
Post by rastageezer on Dec 18, 2015 17:24:51 GMT -5
You should have no problem other than smoother rocks. Look at them and decide how to proceed.
Post by krazydiamond on Dec 18, 2015 17:41:19 GMT -5
ditto, unless it is glass or obsidian, I've let my barrels roll for 3-4 weeks without checking them.
KD
Post by Fossilman on Dec 19, 2015 10:01:12 GMT -5
I run my Obsidian for two + weeks on every cycle..............On most rock,I think the longer you run a cycle ,the better.................
Post by glennz01 on Dec 19, 2015 23:29:57 GMT -5
I'll be cleaning out hopefully tomorrow. With my old tumbler running at 15 rpm I had to tumble for 2 weeks... with this one it runs at 30 rpm so it tumbles in half the time... so I have essentially 6 weeks of tumbling.
Post by jamesp on Dec 20, 2015 7:27:24 GMT -5
For Mohs 7 stones at 27 RPM or 35 RPM SiC 30 grit is like 80 grit in 2-3 days in my barrels. Probably 220 after 5-6 days. Then 400 after 12-14 days.
After two weeks in the last SiC 30 charge they go in the vibe with AO 500 and come out darn shiny. May do a polish after that.
Telling that even very coarse SiC breaks down well in the rotary.
Post by glennz01 on Dec 21, 2015 2:56:09 GMT -5
most of the stones were ready for pre-polish, only a few need to go back to rough grind. I'm starting to clean my last batch of old tumbled stones finally
