jackangeline
Member since December 2015
Post by jackangeline on Dec 31, 2015 17:25:54 GMT -5
Here is what I used for my 14" Diamond Star to prevent a repeat incident of the bronze shoe "safety" from failing (again). It is a Huco mini clutch. 2 disc friction. I had to make an adapter for it. It is part of a 2 part safety for the feed the 2nd part is a rheostat to slow the feed rate. Hope this information is helpful to someone.
Post by MrP on Dec 31, 2015 18:42:28 GMT -5
jackangeline Could you tell us what kind of rheostat you used. Some of those motors don't like certain rheostats. Thanks...........................MrP
jackangeline
Post by jackangeline on Dec 31, 2015 19:11:26 GMT -5
jackangeline Could you tell us what kind of rheostat you used. Some of those motors don't like certain rheostats. Thanks...........................MrP Specs Input: 120 volt AC, Output: 0~130 volt AC, 3 Amp Slow Blow Fuse • Max VA: 300VA, 3 Amp. Max (surge), 1 year warranty • A rating of 300VA means that at 100volt, the unit can sustain at maximum 3amp. If at 120 volt the unit can sustain at 2.5amp • Note that most device have surge (when first turn on) much higher than operating amp rating. • E.g, motor with 3 amp rating may have over 5 amp surge, and you will need 5 amp variac Link www.amazon.com/gp/product/B006NGI8VS?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s00
