Post by jamesp on Jan 23, 2016 15:52:09 GMT -5
Superglue is very strong between flat surfaces. Would it hold up to tumbling ? Opinions ?
Post by Drummond Island Rocks on Jan 23, 2016 16:17:04 GMT -5
Really cool idea. should look great if it works. My first choice would have been 2 part epoxy. I can tell you for a fact it holds rocks better than superglue. learned that the hard way.
Post by jamesp on Jan 23, 2016 16:32:58 GMT -5
Really cool idea. should look great if it works. My first choice would have been 2 part epoxy. I can tell you for a fact it holds rocks better than superglue. learned that the hard way. Chuck Epoxy it is; it holds boats together. That is telling what it does in a wet enviro. Cut those long ago, and hoping the saw oil is long gone. Could have SiC 220 'ed them in the vibe to give a clean glue face. But oil probably absorbs. Could have residual oil within. Best would have been to cut them in water I suppose. But not doing water on the MK saw blade... Not glued yet, needed such advise and thanks.
Post by Drummond Island Rocks on Jan 23, 2016 17:42:05 GMT -5
I really like the devcon epoxy from the rock shed but in a pinch I have used gorilla glue two part epoxy from Home Depot and that worked good too.
Post by jamesp on Jan 23, 2016 18:03:25 GMT -5
I really like the devcon epoxy from the rock shed but in a pinch I have used gorilla glue two part epoxy from Home Depot and that worked good too. Chuck Would get fresh epoxy for such a demanding task too. Devcon has been here before. Epoxy is wicked. Heats up when mixed(gorilla sounds).
Post by Roller on Jan 23, 2016 18:39:02 GMT -5
Great idea .. keep us updated
Post by jamesp on Jan 23, 2016 18:45:26 GMT -5
Great idea .. keep us updated Thanks and will do Roller. The little clamps come in a tube of 22 at Harbor Freight and have darn good squeeze, cheap.
Post by orrum on Jan 23, 2016 19:09:11 GMT -5
Super glue will hold James. You can heat them in the oven and they pop right apart! Then clean the crunchy glue leftovers with a pocket knife. B sure to leave the rocks in the oven to cool slowly. Also b sure they r dry to start with.
Post by Fossilman on Jan 23, 2016 19:17:51 GMT -5
Was thinking of that idea too,but with agate and petwood together......Can't wait for your experiment James...
Post by jamesp on Jan 23, 2016 19:21:04 GMT -5
Super glue will hold James. You can heat them in the oven and they pop right apart! Then clean the crunchy glue leftovers with a pocket knife. B sure to leave the rocks in the oven to cool slowly. Also b sure they r dry to start with. I read that superglue can bond two pieces of glass so well the bond is stronger than the glass if a lot of pressure is used in some cases. That the thinner the layer of glue the stronger the bond gets. Like one of the strongest glue bonds there is. Was not sure about rocks. Or water. Where the heck are you Bill ? How is that solar energy station treating you ? Seen this $380,000 Earthroamer and thought only you could get the most out of it. I think it has $200,000 worth of electronics in it.
Post by orrum on Jan 23, 2016 19:26:25 GMT -5
I am in Sumter Sc James. Flew in from Az last week. My Mommy is in the hospital unhooked from support. Waiting, you know. Cholips and Mic are at the Effus Ranch in Wickenburg Az with my truck and amazing solar setup. It's a real good system with lots of use and proven ability now James. Give Denise a hug for me pardner!
Post by jamesp on Jan 23, 2016 19:29:57 GMT -5
Was thinking of that idea too,but with agate and petwood together......Can't wait for your experiment James... Probably work better if ya glued big slabs and then sawed them into rectangles so tumbling would be quicker.
Post by jamesp on Jan 23, 2016 19:37:52 GMT -5
I am in Sumter Sc James. Flew in from Az last week. My Mommy is in the hospital unhooked from support. Waiting, you know. Cholips and Mic are at the Effus Ranch in Wickenburg Az with my truck and amazing solar setup. It's a real good system with lots of use and proven ability now James. Give Denise a hug for me pardner! So sorry to hear Bill, our prayers are with you and Mom. Denise says hi. Rough times for you. We should be thankful to live such a ripe age. You got siblings ?
