Post by jamesp on Jan 31, 2016 19:51:45 GMT -5
Being used for tumbling fire pit legs. Tilted forward and unloading at beginning of video. Beats de-burring. Grit is granite road gravel. Made out of an assortment of repurposed items obviously.
Post by Fossilman on Jan 31, 2016 21:51:18 GMT -5
Damn,I'm coming to your house-you have more toys to play with.............
bushmanbilly
Member since October 2008
Post by bushmanbilly on Jan 31, 2016 22:58:02 GMT -5
James you should make a open top vib out of one of your fire pits. Would not take much. A solid base, 4 springs and a 1/2 horse motor with a counter weight on the shaft. Would be a big version of the thumbler. Just sayin.
Post by jamesp on Feb 1, 2016 8:08:59 GMT -5
James you should make a open top vib out of one of your fire pits. Would not take much. A solid base, 4 springs and a 1/2 horse motor with a counter weight on the shaft. Would be a big version of the thumbler. Just sayin. Never thought about such. They are elliptical in shape if that means anything. I got tons of heavy springs. I guess you would weld a center structure in the center of the bowl ? : Then copy motor placement from other vibes. it is actually easier to weld up big stuff than working on a small project. Steel is versatile.
Post by broseph82 on Feb 1, 2016 11:08:00 GMT -5
Do it Jim!
Post by jamesp on Feb 1, 2016 12:47:12 GMT -5
May turn out like your washing machine videos LOL.
