arkietumbler
Member since February 2016
Post by arkietumbler on Feb 26, 2016 10:24:50 GMT -5
I purchased a used Lot-O that is in great shape! My question is how to mount?
I bought a cinder block at Lowes yesterday along with a bag of cement to fill in the holes. That should bring the weight of the block to about 60 pounds. I also bought a mismatched quart of latex paint for a buck.
As I understand, I should give the top surface of the block two coats of latex, let dry and then remove the double stick strips from the Lot-O and apply.
The issue is that I have a 'used' Lot-O. Makes sense to me to thoroughly clean the base of the Lot-O, apply some new double-stick tape and move on. If this is the case, how much should I use?
I thought about using Goop or DAP contact adhesive, but I don't want anything permanent as I might move the unit around.
Appreciate your input!
Post by Drummond Island Rocks on Feb 26, 2016 10:57:17 GMT -5
I have three that I bought used. I used construction adhesive to mount a piece of wood to the top of my cement blocks then I bolted the loto's down to the wood. I am sure new two-sided tape would work but make sure its good high quality tape.
