mikeinsjc
Member since June 2010
Post by mikeinsjc on Feb 28, 2016 16:30:18 GMT -5
About a year ago I acquired a 36" Frantom saw (one of four made). I didn't really need it, but the price was right. It required an automobile trailer to transport. Plus, it doesn't have any casters on the legs.
This thing is a beast. The top, though it has a spring assist to help lift it, is still quite heavy. The carriage is screw fed, and can be very difficult to pull back. I'm not getting any younger, so I need ideas to make these two functions a bit easier.
Diamond Pacific uses a hydraulic system to feed and retract the carriage on their 36" saw, but they are built to order and so don't have one in the showroom I could look at. I'm confident I could do the mechanical work of adapting their system to my saw if I could see how it is hooked up. I hesitate trying to come up with my own system, as I haven't any experience in designing that stuff.
The other issue, helping lift the top, seems more do-able. I was thinking of using some of those tailgate lift pistons (like on Suburbans, etc.). But it would be cool to have an all-electric system where I could raise and lower the lid with a single switch.
Does anyone know of any 36" Diamond Pacific saws in the Southern California area that I might look at?
This saw uses a 5hp 21 amp Baldor motor!
Any ideas would be appreciated.
Post by DirtCleaner on Feb 28, 2016 17:45:36 GMT -5
First, congrats on the big saw. Second, we need to see a few pics! Third. I have read others have added the pistons but have not seen them work in person. I would not worry at all about trying it out. Just a couple of small holes in a big chunk of steel I have a Covington 30" saw and the lid is a beast on that one. I would guess it is lighter than yours.A well placed weight on the back may help too. Hundred pounds? Maybe just a 45 lb. barbell weight?
Post by Deleted on Feb 28, 2016 21:25:46 GMT -5
About a year ago I acquired a 36" Frantom saw (one of four made). I didn't really need it, but the price was right. It required an automobile trailer to transport. Plus, it doesn't have any casters on the legs. This thing is a beast. The top, though it has a spring assist to help lift it, is still quite heavy. The carriage is screw fed, and can be very difficult to pull back. I'm not getting any younger, so I need ideas to make these two functions a bit easier. Diamond Pacific uses a hydraulic system to feed and retract the carriage on their 36" saw, but they are built to order and so don't have one in the showroom I could look at. I'm confident I could do the mechanical work of adapting their system to my saw if I could see how it is hooked up. I hesitate trying to come up with my own system, as I haven't any experience in designing that stuff. The other issue, helping lift the top, seems more do-able. I was thinking of using some of those tailgate lift pistons (like on Suburbans, etc.). But it would be cool to have an all-electric system where I could raise and lower the lid with a single switch. Does anyone know of any 36" Diamond Pacific saws in the Southern California area that I might look at? This saw uses a 5hp 21 amp Baldor motor! Any ideas would be appreciated. No, but i do know where there are a pair of hydraulic drive 24". Its the hydraulics you seek. Saw size is less important. It will cost you a $10 donation to the club for access to the workshop. PM me if you want to pursue this. They are in Pomona California.
jerrys
Member since February 2014
Post by jerrys on Feb 29, 2016 11:34:58 GMT -5
Post by johnjsgems on Feb 29, 2016 20:19:54 GMT -5
I think if you call Diamond Pacific they would either send you a saw manual or maybe a PDF version. They had a 36" in their warehouse for a long time but I think they finally sold it. You might want to give the carriage and rails a really good cleaning and coat with grease.
jerrys
Post by jerrys on Mar 1, 2016 11:51:28 GMT -5
I think if you call Diamond Pacific they would either send you a saw manual or maybe a PDF version. They had a 36" in their warehouse for a long time but I think they finally sold it. You might want to give the carriage and rails a really good cleaning and coat with grease. Wouldn't grease would impede the carriage movement? I keep the carriage and rails clean and coat them with clean rock saw oil. I set up my saws so it only takes a very light pressure to move the carriage.
